Page 1 of 2
Trex vs Triceratops
PostPosted: Sat Oct 28, 2017 4:53 pm
by CarbonIX
Zbrush R7 & Octane Render Standalone
Re: Trex vs Triceratops
PostPosted: Sat Oct 28, 2017 6:09 pm
by Terryvfx
Very nice! any other shots in the making? I wish I could see more :D
PostPosted: Sat Oct 28, 2017 9:53 pm
by CarbonIX
Some test renders.
PostPosted: Sat Oct 28, 2017 10:19 pm
by CarbonIX
More test renders.
PostPosted: Sat Oct 28, 2017 11:48 pm
by blackshore
The Sculptures are excellent!
Is this just one mesh per dinosour?
With a one mesh setup without 3d-texture, the closest you can get is a prop.
Octane has no support for 3D-texture as of yet, so if you are going to do a organic creature you are going to do it old school if you are going to get it as realistic as possible.
Which means that you need meshes for muscles, bone, skin, organs, fat separately. The density of each group needs to be set individually.
The bad part about this, is that it will require ALLOT of render time and RAM. :P
PostPosted: Sun Oct 29, 2017 5:43 pm
by Terryvfx
@blackshore What exactly is a 3D texture?
PostPosted: Sun Oct 29, 2017 10:46 pm
by blackshore
Terryvfx wrote:@blackshore What exactly is a 3D texture?
Projection is 3d dimensional projection made out of points.
https://www.youtube.com/watch?v=S84ZoUuJLU8
How to bake:
http://weber.itn.liu.se/~stegu/pixar/Re ... ing3d.html
PostPosted: Mon Oct 30, 2017 5:25 am
by subspark
Umm just use displacement mapping ;_;
PostPosted: Wed Nov 01, 2017 5:57 pm
by blackshore
subspark wrote:Umm just use displacement mapping ;_;
Please do not troll here.
Displacement map is primarily used for static meshes if in rush. It still needs the polycount to work since it just pushing verts in one axis.
You can use displacement for increasing speed of an landscape if you are in rush.
If you have time: Displacement>Increase polycount until it looks good>Bake to Mesh>Tesselate>Remove displacement and save ram.
PostPosted: Fri Nov 03, 2017 3:56 am
by subspark
Lose the attitude thanks blackshore. 3d textures will slide with no correlation to movement. In other words details will appear to swim which produce undesierable and unreleatic results.
Displacement maps work marvellously for realistic animated creatures such as dinosaurs.
You didn’t specity your ultimate goal or what equipment you’re using, howeve you could use a number of high resolution textures, for quality output with no detectable stretching.
Combined with a skin/muscle system you could render out some holywood-level shots.
Go for it CarbonIX!
