Small house / winter scene
Forums: Small house / winter scene
Postby ubicz » Wed May 17, 2017 6:35 am
ubicz Wed May 17, 2017 6:35 am
Small house presentation for an office I work at.
Done in Octane for c4d and Photoshop
The house design was created by Domowe Klimaty - architectural office. It's really small house (about 70 sq. meters usage area), supposed to be very cheap.
Snow on the ground is done with displacement, including the foot leads. It's kinda funny, cause till version 3.05 I couldn't use displacement (wierd artifacts appeared, when I tried to mix to many displacement materials). After update it started to work.
Snow on the roof and other object = 3D sculpting, only some of the snow on the trees was done with magicSnow plugin (based on c4d particles system). Material is nothing fancy, very simple glossy type with noise in roughness and bump.
Light was done with simple octaneDayLight, with HDRI as a backplate (and for reflections).
Render settings:
Max sampless: 4500
Diff. depth: 6
Specular depth: 8
Ray epsilon: 0.0001
Filter size: 1.2
Caustic blur: 0.02
GI clamp: 201
Path. term. power: 0.3
Coherent ratio: 0
Parallel samples: 8
Max til samples: 16
Octane 3.05 with Cinema 4D / Win10 / AMD 8150 FX / 1x GeForce 1070 GTX / 16 GB DDR 3
ubicz
Re: Small house / winter scene
Postby zinogino » Wed May 17, 2017 7:32 am
zinogino Wed May 17, 2017 7:32 am
Liked the 1st image but the 2nd image background doesn't seem to blend well
zinogino
Postby ubicz » Wed May 17, 2017 1:30 pm
ubicz Wed May 17, 2017 1:30 pm
Thanks for the comment ^^
zinogino wrote:the 2nd image background doesn't seem to blend well
Yea, I did this render few months ago and I thought it was fine, but now I can see that background is weird. Guess I can call it a "progress" :P
ubicz
Postby Marvez » Wed May 17, 2017 3:49 pm
Marvez Wed May 17, 2017 3:49 pm
nice work , can you share some things about how you made it ?
I7 5820K 16MB RAM SSD850PRO GTX 970/780
Marvez
Postby ubicz » Wed May 17, 2017 7:51 pm
ubicz Wed May 17, 2017 7:51 pm
Marvez wrote:nice work , can you share some things about how you made it ?
Sure, I will edit original post and add some technical info :)
If you want some specific info, pls let me know and I will add it aswell!
ubicz
Postby Marvez » Wed May 17, 2017 8:06 pm
Marvez Wed May 17, 2017 8:06 pm
look forward to it
Marvez
Postby ubicz » Thu May 18, 2017 6:59 am
ubicz Thu May 18, 2017 6:59 am
Done ;)
ubicz
Return to M is for Metaverse Gallery
Users browsing this forum: Bing [Bot] and 11 guests
Fri Oct 23, 2020 9:59 pm [ UTC ]
