Back to loft
Forums: Back to loft
Back to loft
Postby enricocerica » Tue Jun 04, 2013 8:13 pm
enricocerica Tue Jun 04, 2013 8:13 pm
I'm trying to get some more crispy images with more relief and contrasted light.
Definitely impossible using only DL mode 3, so this time I opted for DL mode 4 trying to increase the light by adding emits on the windows. Quite slow but I think it is the only way to get something more realistic from light point of view. Not yet the result I expect but not so far, I'll investigate a bit more.
Render time : about 1h on two gtx580
Postpro : mix with a DL mode 3 render to increase light on some areas and to get more white walls.
I also tried using PMC but after about 2 hours I stoped, too noisy.
More to come ...
http://www.myline.be
enricocerica
Re: Back to the loft
Postby merid888 » Tue Jun 04, 2013 11:03 pm
merid888 Tue Jun 04, 2013 11:03 pm
that curtain looks so heavy, maybe the color is not correct, is my humild opinión
nice image enrico
W10 x64 Bits, 32 Gb 3200 Mghz DDR4, Aorus B550M AMD 4, Ryzen 7 3700x 3.6 Ghz, M2 Kingston A2000 512 Gb, Air Sink Noctua Nh-d15, 1 GTX 1080 Ti OC 11 GB ROG STRIX, 1 Power Supply Thermaltake 850 W.
merid888
Re: Back to loft
Postby enricocerica » Fri Jun 07, 2013 7:02 pm
enricocerica Fri Jun 07, 2013 7:02 pm
Thanks Merid888,
Indeed, the room is dark/contrasted and maybe I should make the curtains less dark or a bit transparent.
Not much time to work on the scene for now, so will post something else later.
enricocerica
Re: Back to loft
Postby Mauricio Gomes » Mon Jun 10, 2013 6:20 pm
Mauricio Gomes Mon Jun 10, 2013 6:20 pm
in my opinion the corners of the wall and ceiling are too dark but overall the scene is quite nice, especially the carpet...is very good. ;)
win 7 - Nvidia gtx 680 + gts 450
Mauricio Gomes - 3d generalist
http://www.mandrakeimage.com.br
Mauricio Gomes
Return to M is for Metaverse Gallery
Who is online
Users browsing this forum: No registered users and 8 guests
Tue Jan 26, 2021 3:28 pm [ UTC ]
