diningroom
Forums: diningroom
diningroom
Postby gabrielefx » Mon Jul 16, 2012 8:51 am
gabrielefx Mon Jul 16, 2012 8:51 am
original render 4000x3000 px
printable render 3500x2480 px
rendering time 12 hours (about) - 4xGTX580
13000 pps reached (about)
gabrielefx
Re: diningroom
Postby tonycho » Mon Jul 16, 2012 9:37 am
tonycho Mon Jul 16, 2012 9:37 am
Hi Gabriele, another great rendering
I am a fan of your rendering :D
do you use mix material for the white area?
is it help to make the rendering clean faster?
http://www.antoni3D.com
Win 7 64 |GTX 680 4 Gb (Display) | 3 x GTX690 4Gb | Intel i5 |Corsair 16GB
tonycho
Re: diningroom
Postby gabrielefx » Mon Jul 16, 2012 10:15 am
gabrielefx Mon Jul 16, 2012 10:15 am
tonycho wrote:Hi Gabriele, another great rendering
thank you.
I always mix diffuse materials because there is always a specular (glossy) component in every material.
The only thing that reduces the noise is a well distributed illumination.
gabrielefx
Re: diningroom
Postby tonycho » Mon Jul 16, 2012 10:37 am
tonycho Mon Jul 16, 2012 10:37 am
I see
Thanks for the tips :)
tonycho
Re: diningroom
Postby RobSteady » Mon Jul 16, 2012 11:41 am
RobSteady Mon Jul 16, 2012 11:41 am
It's a good render, but 12 hours on 4 gtx580 and with that much noise in it ??? :shock:
I was really thinking about switching to octane from v-ray one day but this is a big argument against that.
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
RobSteady
Re: diningroom
Postby glimpse » Mon Jul 16, 2012 12:14 pm
glimpse Mon Jul 16, 2012 12:14 pm
Nicely balanced piece Gabrielefx. Cozy to say at least =)
RobSteady wrote:It's a good render, but 12 hours on 4 gtx580 and with that much noise in it ??? :shock:
The bigest savings useing unbiased renders like Octane are made on human resources, not on the hardware..or rendering times. Human factor, the hours we have to put costs most in the field =) the hardware is just a fracture of that - month or two of what company has to pay for artist, when typical build might last for a year or two =)
tomGlimps | [email protected] | 32GB | TitanBlack
Available for Freelance, Coaching & Mentoring
glimpse
Re: diningroom
Postby marcio_max » Mon Jul 16, 2012 3:40 pm
marcio_max Mon Jul 16, 2012 3:40 pm
Hi, Gabriele!
Great work! :lol:
Pathtracing or PMC?
| Windows 8 Pro x64 | Octane for 3ds Max/Standalone | i7 860 | 12GB RAM | 1x EVGA GTX 670 4GB / 2x EVGA GTX 670 2GB | Cooler Master HAF 932 |
marcio_max
Re: diningroom
Postby gabrielefx » Mon Jul 16, 2012 4:33 pm
gabrielefx Mon Jul 16, 2012 4:33 pm
you are right,
I forced a little bit the tonal contrast in the first photoretouched image. I added a different (cold) version.
The 3500x2500 pixels version has noticeable noise but I reduced it with Nik Dfine.
I don't use trick to illuminate a scene, I don't delete the ceilings. All materials are glossy+diffuse, many have sss.
Only one light panel stay behind the sofas because I had to balance indoor/outdoor exposure.
I used pmc but for a noiseless 4000x3000 render (the counter predicted 19 hours for 24.000 samples) we need new algorithms for noise reduction or decent Nvidia GTXs 3-4 times faster than our 580s.
Here the crop
gabrielefx
Re: diningroom
Postby tonycho » Mon Jul 16, 2012 8:15 pm
tonycho Mon Jul 16, 2012 8:15 pm
Hi Gabriele
have another question
why dont you use glossy material then increased some roughness etc
instead using mix material of diffuse and glossy :?:
do you found any different?
thanks before :)
TOny
tonycho
Re: diningroom
Postby gabrielefx » Wed Jul 18, 2012 10:52 am
gabrielefx Wed Jul 18, 2012 10:52 am
thanks before :)
TOny
Octane has an issue with smoothing. If you add a glossy mat with high roughness you will get dark surfaces if these surfaces are not facing the camera. Blending glossy+diffuse you will avoid this issue.
During this work I found a trick on how reduce the noise (not the rendering time).
Portal doesn't help to pass lights through widows . Then is a lot better to add invisible rectangular lights in front every window.
All the scene will receive more light and well distributed.
It's important to use glossy material for the glass with transparency set at 0,1, roughness at 0, reflection at 1, fresnel at 1.6
I added another shot.
gabrielefx
Next
Return to Gallery
Users browsing this forum: Google [Bot] and 5 guests
Thu Nov 14, 2019 1:25 pm [ UTC ]
