Rendering issues
Forums: Rendering issues
Rendering issues
Postby spartan00j » Mon Aug 08, 2022 7:59 pm
spartan00j Mon Aug 08, 2022 7:59 pm
Hello, when rendering in octane I can see the polygons on the surface.
This 3D model was an original CAD file that I converted into an obj file.
If that matters.
I think I ran into this problem before.
But it's been a long time since I've been in octane.
So I have to refresh myself on all the troubleshooting.
Thanks for your help.
Win 10
Threadripper 1920x
128GB RAM
RTX 3060 TI
spartan00j
Re: Rendering issues
Postby elsksa » Mon Aug 08, 2022 10:09 pm
elsksa Mon Aug 08, 2022 10:09 pm
G.I.G.O applies here.
If a broken mesh is brought to Octane, there will be no micracle, Octane will output the broken mesh.
Ensure the mesh is properly triangulated, then double-check mesh-normals and Octane's smooth material option.
elsksa
Postby face_off » Mon Aug 08, 2022 11:22 pm
face_off Mon Aug 08, 2022 11:22 pm
It looks like the normals are messed up. Render one of the Normals passes to check for sure.
Postby spartan00j » Tue Aug 09, 2022 12:19 am
spartan00j Tue Aug 09, 2022 12:19 am
elsksa wrote:Hi,
Thanks I unticked smooth and it made it better
Win 10
Threadripper 1920x
128GB RAM
RTX 3060 TI
spartan00j
Postby spartan00j » Tue Aug 09, 2022 12:20 am
spartan00j Tue Aug 09, 2022 12:20 am
face_off wrote:It looks like the normals are messed up. Render one of the Normals passes to check for sure.
Sorry I don't quite understand what does that mean. render one of the passes. I haven't used octane in a while
I feel like a noob> :cry:
Win 10
Threadripper 1920x
128GB RAM
RTX 3060 TI
spartan00j
Postby face_off » Tue Aug 09, 2022 5:10 am
face_off Tue Aug 09, 2022 5:10 am
Settings Tab->Render AOV's->Normal (shading)->Open Viewport and you will so the polygon UV's in RGB format which I am guess will show that they are corrupt.
Postby spartan00j » Tue Aug 09, 2022 3:04 pm
spartan00j Tue Aug 09, 2022 3:04 pm
face_off wrote:Settings Tab->Render AOV's->Normal (shading)->Open Viewport and you will so the polygon UV's in RGB format which I am guess will show that they are corrupt.
Thanks, But it looks fine.
Win 10
Threadripper 1920x
128GB RAM
RTX 3060 TI
spartan00j
Postby face_off » Wed Aug 10, 2022 12:40 am
face_off Wed Aug 10, 2022 12:40 am
Can you send me the OBJ file please?
Postby spartan00j » Sun Oct 02, 2022 10:09 am
spartan00j Sun Oct 02, 2022 10:09 am
face_off wrote:Can you send me the OBJ file please?
It's okay now. I finished the project. I forgot to say the client gave me a 3D model engineered file that was in a STL format. I converted it to obj. Most likely that caused the problem. But I was able to work with it without issue.
Win 10
Threadripper 1920x
128GB RAM
RTX 3060 TI
spartan00j
Return to Poser
Users browsing this forum: No registered users and 7 guests
Thu Apr 18, 2024 7:48 pm [ UTC ]
