Hey Paul,
I just recently started using octane again after taking a break from animating for about a year-and-a-half. I wanted to request small adjustments for productivity's sake.
1. I know I asked for an undo feature when changing settings around two years ago. is that still not possible?
2. Also, I know you can right-click a texture (Or multiple) and converted to diffuse but can there be added a feature where you can convert it to any other types of materials with one click? Like if I want it to select 10 textures at the same time and convert all of them to toon materials.
3. And lastly is there a way to change one setting with all selected material nodes. For example, if I right-click on the roughness node setting value in one material node and click copy. And then I will select five other material nodes and right quick and click paste. To change all the roughness node settings of those material knows node that I selected to the value that I copied in step one. Instead of going into each material node one-by-one and changing the roughness node value.
P.S Good to be back and see all the great changes to the plug-in and Octane.
