light sphere material transfer
Forums: light sphere material transfer
Postby gsfcreator » Thu Apr 19, 2018 8:55 pm
gsfcreator Thu Apr 19, 2018 8:55 pm
I have an object that acts as a magical ball/sphere. it got all kinds of textures/materials. generally, it's a sphere with a special textures. Octane doesn't import it correctly.
here it is in firefly:
this is how octane imports:
after some tweaks (color change/opacity) that's what I could get. it won't show the "magical" texture:
poser material nodes:
I'm trying to figure out why this is happening with some materials, while others (most of them, actually) transfer without any problem.
thanks for your help.
Core I7-8700K, 32RAM, GTX1080Ti, win10
gsfcreator
Re: light sphere material transfer
Postby face_off » Thu Apr 19, 2018 11:33 pm
face_off Thu Apr 19, 2018 11:33 pm
I think you might need a Diffuse material with an Emission.
Postby gsfcreator » Fri Apr 20, 2018 3:50 pm
gsfcreator Fri Apr 20, 2018 3:50 pm
face_off wrote:I think you might need a Diffuse material with an Emission.
the thing is, I can't animate the lights (Emitters) in octane (or can i?). when I want to do a simple thing, such as creating a flickering light sphere, I keyframe the sphere/the light attached to it in poser. is there any way do achieve this in octane?
also, how do I control the fall-off of the light?
gsfcreator
Postby face_off » Sun Apr 22, 2018 7:25 am
face_off Sun Apr 22, 2018 7:25 am
You should be able to use dial-linking to do this. Connect the emitter power to a dial and keyframe that dial.
https://docs.otoy.com/PoserH/PoserPluginManual.htm#Poser/DialLinking.htm
Postby gsfcreator » Sun Apr 22, 2018 12:58 pm
gsfcreator Sun Apr 22, 2018 12:58 pm
face_off wrote:You should be able to use dial-linking to do this. Connect the emitter power to a dial and keyframe that dial.
thanks, Paul! so much to learn.
gsfcreator
Return to Poser
Sun May 31, 2020 1:54 pm [ UTC ]
