making skin look sweaty (more glossy)
Forums: making skin look sweaty (more glossy)
Postby gsfcreator » Thu Apr 05, 2018 2:13 pm
gsfcreator Thu Apr 05, 2018 2:13 pm
hello there!
new user here, trying to figure out octane render engine for poser.
what parameter should I tweak to get skin a little sweaty look?
thank you <3
Core I7-8700K, 32RAM, GTX1080Ti, win10
gsfcreator
Re: making skin look sweaty (more glossy)
Postby wimvdb » Thu Apr 05, 2018 2:28 pm
wimvdb Thu Apr 05, 2018 2:28 pm
The specular ior and roughness define the glossines of a material.
It will be more visible if you use a bump or normal map due to the different directions the light will bounce.
Most realistic result would be to set IRO to 1.33, set roughness very low and increase specular value.
RedSpec has made a series of human skins and wet skins you can apply to your own characters. http://redspec-sss.com/shop_skin.html
It gives quite good results. If you are using Poser and M4/V4 get the M4F ones for Poser.
Configuration: Windows 10 64bit Creators Edition, I7 6850K, 128GB, 2 GeForce 1080ti, P11 Pro SR6
wimvdb
Postby gsfcreator » Thu Apr 05, 2018 8:09 pm
gsfcreator Thu Apr 05, 2018 8:09 pm
wimvdb - you are a poser archangel! thanks! :-)
gsfcreator
Return to Poser
Who is online
Users browsing this forum: No registered users and 3 guests
Mon Jul 06, 2020 7:02 am [ UTC ]
