Using 'Image adding'
Posted: Mon Jun 05, 2017 11:40 pm
Okay, I have a problem which I have for multiple renders. A lot of the Poser node setups where I 'add' two textures together without modifying the original. Here are some examples.
1. I have an alpha map of an area which I want to 'glow' and then multiply it with the color to get a glow of that color in that pattern, which I can then apply to an emission node in Poser. There is, however, no way to do that in Octane that I can see. I have tied multiply, but that is only changing the size of the texture scale, NOT 'color math' multiplication. Mix also doesn't work, as it will destroy the color.
2. One of my favourite node setups for tattoos on skin is to use color math to add a tattoo to a skin texture, either a full color one, or using an alpha like above to map out just that area with any color.
Can these be accomplished in Octane's node setups? I know, for example, Emission will accept the alpha picture, but it can't change the color on the fly, you have to change the color on the alpha before you input it. As for the tattoo, I have no idea.
