remove
Posted:
Tue Feb 11, 2014 1:21 am
by gold
disregard
Re: Need 117 version
Posted:
Tue Feb 11, 2014 1:24 am
by face_off
May I ask why you need such an old version? That is from July last year. Won't a later version work for you?
Re: remove
Posted:
Tue Feb 11, 2014 1:26 am
by gold
wow Paul, that was fast LOL>
I just found it . I need it because I was about to install the latest - then saw your ominous warning
that older files WONT open. So I have to go back and use this.
thanks
Re: remove
Posted:
Tue Feb 11, 2014 1:33 am
by face_off
That's not what the warning says. It says if you save with the 1.29 version, you cannot then open with the 1.20 version. But 1.29 is very robust now - and safe to migrate to, as low as your video card is not very old (anything from the GTX 500 series onwards is fine).
Re: remove
Posted:
Tue Feb 11, 2014 1:39 am
by gold
Oh Ok, my bad.
So I can open old files with the new version - but just cant save them for an older version reopen.
Can I now install 129 directly over my old version 117 install? Or do I have to edit files by hand?
thanks
Re: remove
Posted:
Tue Feb 11, 2014 1:51 am
by face_off
You can just install over the top of 1.17. You shouldn't need to edit any files. However make sure you following the instructions at the top of the 1.29 TEST thread - specially regarding deleting your old default rendertarget.
Re: remove
Posted:
Tue Feb 11, 2014 2:00 am
by gold
ok, I see those directions.
I don't have this path here: { is this path correct for win7 -64 ? }
(delete
C:\Users\[username]\AppData\Roaming\Poser Pro\10\defaultrendertarget.por)
and recreate them again in the plugin.
also, will i even have anything to change, since I just installed 117, authorized it, but havent
rendered anything yet?
Re: remove
Posted:
Tue Feb 11, 2014 2:10 am
by face_off
(delete
You need to replace the [username] part above with your Window login username.
You do not need to delete the defaultrendertarget.por file in this case.
Re: remove
Posted:
Tue Feb 11, 2014 11:58 am
by gold
thanks Paul,
Installed and seems to be working.
