Tubulence node for skin
Forums: Tubulence node for skin
Postby Erick » Sun Jun 02, 2013 1:05 pm
Erick Sun Jun 02, 2013 1:05 pm
BB makes/made amazing skin shaders for Poser. He often (if not most of the times) uses a turbulence node, instead of a bump map.
Did anyone try this out with Octane and their V4 figure(s)?
I played a bit with it over the weekend, but I have to admit, I haven't found out a right, or good setup yet.
I always get confused with the Octane turbulence node. Which version of the node to use (the 1, 2 or 3 float version with the x, y, z directions for the effect) and into which bump channel to set it up, when having a mix material, like diffuse and spec./glossy, since all of these materials are having a bump channel.
Any suggestion would be welcome =)
Erick
Re: Tubulence node for skin
Postby face_off » Sun Jun 02, 2013 1:11 pm
face_off Sun Jun 02, 2013 1:11 pm
I prefer turbulence or marble to the Poser bump maps. Just leave scale at "float", and I think I used a scale around 30.
Postby Erick » Sun Jun 02, 2013 2:20 pm
Erick Sun Jun 02, 2013 2:20 pm
Thanks, Paul.
... and where would you suggest setting up the bump, when having something like a mix material with diffuse + glossy, or diffuse + spec.? In both mats? or in just one?
About the scales in Octane .. Poser, for something like bump or displacement, is much easier for me to understand.
In my job, I have to use metric volumes on a daily base. So I can set up Poser to use something like millimetres for example, set the bump value to 0.5 and have a clear sight, of "how much" this value is. Octane is much more unclear for me, with it's 0-1 range ... But it's all good .. and I can't wait for the Titan I'll order soon =)
Erick
Postby ch0pper » Sun Jun 02, 2013 2:37 pm
ch0pper Sun Jun 02, 2013 2:37 pm
do you have any info on this url want check it out?
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
ch0pper
Postby Erick » Sun Jun 02, 2013 3:10 pm
Erick Sun Jun 02, 2013 3:10 pm
Over at runtimedna.com forums, in the official one for P9/PP12, he demonstrated various skin set ups.
If you search by the user "Bagginsbill", you'll eventually find it.
Later then BB's shader made it's way into Snarly's "EZSkin2" skript (http://snarlygribbly.org/3d/forum ) . So with one push-the-button, these complicated shaders will find their ways into the different (V4-) mat.zones.
...EZSkin(2) is such a must have for Poser, imo. :D
Erick
Postby ch0pper » Sun Jun 02, 2013 9:14 pm
ch0pper Sun Jun 02, 2013 9:14 pm
thanks for that but does this work with octaine?
ch0pper
Postby face_off » Sun Jun 02, 2013 9:17 pm
face_off Sun Jun 02, 2013 9:17 pm
I ended up putting it in both mix inputs (ie. the diffuse and the glossy). I worked out the approx values first using just the standard glossy skin shader. I don't think I ever got to the point of "that's it!", otherwise I would have documented the final values here.
Return to Poser
Thu Jan 28, 2021 5:32 am [ UTC ]
