Page 3 of 4
Re: Poser Pro 2014 problems
Posted:
Sun Jun 02, 2013 12:50 am
by Iefke
Wow, your quick!
I tried 1.16a6 on both PP2012 and PP2014 and unfortunatly the problem remains.
Yvo
Posted:
Sun Jun 02, 2013 2:05 am
by face_off
OK, I will post another version in an hour or two. In the meantime, can you post the latest .wer file in your c:\users\<yourname>\AppData\Local\Temp folder? It should be the Poser crash file, and be dated today.
Posted:
Sun Jun 02, 2013 3:56 am
by face_off
I have some more info on this....it appears this problem is due to the event mechanism behind wx.python (which is the PoserPython GUI which the Octane plugin uses). It appears certain versions of the Microsoft common controls respond differently to the tree selection event, and some versions fire the select event twice which is causing the plugin to get into a loop, which ends up in a crash.
I have updated the
http://render.otoy.com/customerdownloads/plugins/OctaneRender%20for%20Poser%20Setup%201.16a6%20beta.exe installer to add more verbose output to the octaneplugin.log file so that I can get a better handle of where exactly the crash is happening. Can you pls try this revised version, and once you get a crash, send me the octaneplugin.log file, and let me know which node you changed the type of to cause the crash.
Posted:
Sun Jun 02, 2013 9:34 am
by Iefke
Thanks Paul, i will test this.
Right now i have some Sunday duties to do, like cooking for my family, etc...
I will come back.
Yvo
Posted:
Sun Jun 02, 2013 1:03 pm
by Iefke
Paul,
I sended the logs to your Physicalc address.
Yvo
Posted:
Sun Jun 02, 2013 9:38 pm
by face_off
I have 2 leads on this issue.....
1) Are the 3 or 4 people experiencing the node type change crash all running a non-English version of Poser? Is anyone running the English version getting this crash?
2) I could be the version of the Microsoft Common Controls you have installed. Can the people experiencing this problem pls report the version of the Windows common controls they are using? To do this, check the C:\Windows\WinSxS\ folder - the common controls are named something like amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9200.16579_none_418ab7ef718b27ef\COMCTL32.dll, which is version 6.0.9200.
Posted:
Mon Jun 03, 2013 1:08 am
by Iefke
I have the English version of Poser running on a Dutch Windows 8 64bit
I have 4 common controls files:
amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9200.16384_none_7762d5fd3178b04e
amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9200.16384_none_418c2a697189c07f
amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9200.20683_none_2abe9a298b310786
Yvo
Posted:
Mon Jun 03, 2013 1:34 am
by face_off
It looks like the common factor is Windows 8!
Posted:
Mon Jun 03, 2013 4:06 am
by face_off
I have re-uploaded
http://render.otoy.com/customerdownloads/plugins/OctaneRender%20for%20Poser%20Setup%201.16a6%20beta.exe, which /should/ fix the issue people are having. Once I get confirmation of this from people, I'll post this version as the new 1.16a TEST release.
Posted:
Mon Jun 03, 2013 9:58 am
by Iefke
Paul,
You fixed it !!!
No more crashes, tested in both PP2012 and 2014.
Thanks for your support!
Yvo
