Change Color in Poser not changing in Octane
Forums: Change Color in Poser not changing in Octane
Postby morphious2013 » Fri May 31, 2013 12:45 am
morphious2013 Fri May 31, 2013 12:45 am
Changed the color of an object in Poser, hit refresh in Octane, but still renders the original color.
BTW. The newest version of plugin renders 3 times faster for me for some reason. Awesome.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
morphious2013
Re: Change Color in Poser not changing in Octane
Postby face_off » Fri May 31, 2013 12:49 am
face_off Fri May 31, 2013 12:49 am
How are you changing the color? Are you changing the Poser material color in Poser, or the Octane material color in the plugin?
Postby morphious2013 » Fri May 31, 2013 12:54 am
morphious2013 Fri May 31, 2013 12:54 am
in poser
morphious2013
Postby face_off » Fri May 31, 2013 1:03 am
face_off Fri May 31, 2013 1:03 am
If you change a material in Poser, you need to reconvert that material int he plug. Rightclick the material in the material tab and "reconvert from poser". The better workflow is to change the color in the plugin directly, rather than in Poser.
Postby morphious2013 » Fri May 31, 2013 1:09 am
morphious2013 Fri May 31, 2013 1:09 am
OK, thanks. BTW... What ever changes you made to the plugin, it renders 3 times faster for me. What did you do? Thanks again for your help.
morphious2013
Postby morphious2013 » Fri May 31, 2013 1:15 am
morphious2013 Fri May 31, 2013 1:15 am
1 more thing. It's a bed sheet and pillow. Can I give a "cloth" like bump or material to them in Octane Plugin, or do I need to do it in Poser? Thanks.
morphious2013
Postby morphious2013 » Fri May 31, 2013 1:24 am
morphious2013 Fri May 31, 2013 1:24 am
I added a cloth texture in Poser as a bump, and in Octane Plugin, right clicked to re-import material from poser, but still no joy.
morphious2013
Postby face_off » Fri May 31, 2013 1:52 am
face_off Fri May 31, 2013 1:52 am
If you post a screenshot of the Poser material and the Octane material, we can see what you are trying to achieve.
Basic workflow of the plugin is covered in the manual, so it may be worth you having a read through it.
Return to Poser
Mon Mar 30, 2020 7:39 am [ UTC ]
