Skin glossiness
Forums: Skin glossiness
Skin glossiness
Postby mitzzy50 » Mon May 13, 2013 2:53 pm
mitzzy50 Mon May 13, 2013 2:53 pm
I hope I can explain my problem clearly. I want to increase the ''shiny'' of the skin of my V4. She is using a ''normal'' skin, the most standard, if that makes sense. I tried increasing the specular in the material tab in Poser. I tried changing the specular and roughness in the material tab in the plug-in. I don't know what else I can do. Perhaps someone can help me. Thank you in advance
mitzzy50
Re: Skin glossiness
Postby KleanZlate » Mon May 13, 2013 3:06 pm
KleanZlate Mon May 13, 2013 3:06 pm
What settings did you try for the roughness node?
Windows 8 64bit, Intel Xeon 3.4 GHz x2, 10GB RAM, GTX 660 Ti 2GB, Poser Pro 2012 SR 3.1
KleanZlate
Re: Skin glossiness
Postby mitzzy50 » Mon May 13, 2013 3:19 pm
mitzzy50 Mon May 13, 2013 3:19 pm
The maximum it allows in the plugin. 1.0 I think?
mitzzy50
Re: Skin glossiness
Postby badmilk69 » Mon May 13, 2013 3:30 pm
badmilk69 Mon May 13, 2013 3:30 pm
My settings for V4 (well oiled edition) are:
Material: Glossy
Specular: 0.3
Roughness: 0.1 - 0.3
Index: 1.3
i7 2600, 16 GB RAM, 2x Evga 670 SC 4gb, dual boot win7/osxML, 2 SSDs, 3 HDs.
badmilk69
Re: Skin glossiness
Postby Witpapier » Mon May 13, 2013 3:32 pm
Witpapier Mon May 13, 2013 3:32 pm
I found that changing skin from Glossy to specular give increases the effect, decreasing the roughnes and increasing the specular values will make your character look shiney like oil.
RedSpec TGX for Poser / OctaneRender - OUT NOW visit http://redspec-sss.com/
Witpapier
Re: Skin glossiness
Postby KleanZlate » Mon May 13, 2013 5:04 pm
KleanZlate Mon May 13, 2013 5:04 pm
mitzzy50 wrote:The maximum it allows in the plugin. 1.0 I think?
Roughness decreases or widens the specularity with higher numbers. Try Witpapiers settings. You could even go lower like 0.05 or even lower. If the there is a specular image map controlling the specularity you might try replacing it with a floattexture node. Also test the filmwidth setting. if it's at 1 try a little lower setting.
KleanZlate
Re: Skin glossiness
Postby face_off » Mon May 13, 2013 11:11 pm
face_off Mon May 13, 2013 11:11 pm
As everyone else said - get more glossiness/shininess by reducing the roughness.
Re: Skin glossiness
Postby mitzzy50 » Tue May 14, 2013 6:59 am
mitzzy50 Tue May 14, 2013 6:59 am
Oh wow, thank you so much, I thought I had to increase the roughness... Its the other way, decreasing it increase the ''shine''
mitzzy50
Re: Skin glossiness
Postby mitzzy50 » Tue May 14, 2013 7:05 am
mitzzy50 Tue May 14, 2013 7:05 am
I forgot... I just wanted to say that I'm really grateful with this community. You're all so helpful and quick :) Thank you all
mitzzy50
Return to Poser
Users browsing this forum: No registered users and 7 guests
Fri Apr 19, 2024 10:17 am [ UTC ]
