Page 3 of 5
Re: OctaneRender® for Poser beta - build 1.13u [TEST]
Posted: Sun Apr 28, 2013 11:43 pm
by face_off
The first thing I did was try to switch texture environment floattexture to image, and got an error message that I didn't record. So I left that alone and just tried to move the camera (with the render window open), and got this message in a window titled "delete lights":
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 10465, in poserEvent
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 8912, in setOctaneCameraInfo
WindowsError: exception: access violation reading 0x000000000000001C
I am pretty sure this is a ramification of the "texture environment" bug, which was fixed with the last update (which is not working for some ppl.
I am uploading a fix right now.
Posted: Sun Apr 28, 2013 11:49 pm
by face_off
New version available from the link in the first msg of this thread.
1.13a-2
- Fixed bug where Octane library would not load
- Stopped debug print statement "rez lock on change event"
Posted: Mon Apr 29, 2013 5:44 pm
by bblogoss
Now it works again.
Thanks for the quick fix.
Posted: Mon Apr 29, 2013 6:44 pm
by RGUS
Seems stable... been using it for a couple of renders in both environments.
Posted: Mon Apr 29, 2013 9:13 pm
by Xipomus
Update looks good. No more wacro and textures seen to work like they should too.
Thanks for the update... should anything occure I will let you know.
Posted: Wed May 01, 2013 10:55 am
by face_off
I just put a small patch through. Keep a copy of your old installer just in case. Download the new patch from the link at the top of this thread.
1.13u-2
- Fixed issue where plugin could not be activated if Octane Standalone was not activated
- Change account authorisation to be when the plugin is first run for a session, rather than when Poser first starts up
- Added "Show node Graph" to display the node graph for the selected tree item. Added for testing purposes only. Highly experimental - use at your own risk. Clicking "Unfold" on a big scene will potentially hang Poser.
- Added "Show Log" button to the Cuda tab to display cuda diagnostic info
- Changed underlying architecture to be more closely aligned to the forthcoming Mac version of the plugin
- Render priority is now saved between sessions
- For specular materials, "fake_shadows" defaults to Enabled
Posted: Wed May 01, 2013 10:56 pm
by face_off
There was a cosmetic issue with the last version where the tree was not being restored after changing the node type. I have just re-uploaded 1.13u-2 to rectify this issue. I also removed the Mac installer for the moment to save download size.
I also have a report that this version has an issue with emitters which use opacity maps. I have escalated this to Otoy.
Posted: Thu May 02, 2013 4:10 am
by face_off
I have investigated this further, and the version of Octane this latest version of the plugin has been compiled against has a problem with transmapped materials. So hair is not rendering correctly :-\ So pls hold off downloading and installing this version until I get a fix out.
Apologies for the glitch.
Posted: Thu May 02, 2013 9:58 pm
by face_off
Quick update - Otoy have confirmed the issue with transmapped materials, and I hope to have a fix out in the next 1-2 days.
Posted: Fri May 03, 2013 2:50 am
by gold
Hello,
I dont understand what standalone goes with the 113 poser plugin?
all I see is 100 or 110 standalone available for download. { windows 64}
thanks
