Rendering Animation Bug
Forums: Rendering Animation Bug
Postby spartan00j » Tue Sep 06, 2022 2:49 pm
spartan00j Tue Sep 06, 2022 2:49 pm
Hey paul, I found a bug when rendering animations. When rendering animations every few frames the render does not complete the complete samples that I set it at. I will try to adjust the sample bit rate multiple times including to a higher level. But I still get the same effect.
See attachments.
I thought I might be just rendering too fast but setting the sample all the way up to 600 I get the same results every few frames. It seems like every few frames it will render one real quickly not to the full sample that was selected.
Render-test.zip
(73.49 MiB) Downloaded 209 times
Win 10
Threadripper 1920x
128GB RAM
RTX 3060 TI
spartan00j
Re: Rendering Animation Bug
Postby face_off » Wed Sep 07, 2022 5:09 am
face_off Wed Sep 07, 2022 5:09 am
Hi. I am away from the office for the next 8 days. I will look at this issue when I return.
Postby spartan00j » Sun Oct 02, 2022 9:13 am
spartan00j Sun Oct 02, 2022 9:13 am
Paul,
I've uploaded the frames and a video showing the bug. The first frame is black. And it looks like every even number frame(3,5,7, and 9) doesn't render completely. It looks like as you can see in the bottom left of the video that the sample value doesn't even count up to the render Target of 20. In fact, the sample render stays at 20 from the last frame rendered and doesn't count up as it should.
This is not a big issue for me right now since I export the animation and render it in the stand-alone.
Render Bug.zip
(69.92 MiB) Downloaded 193 times
Win 10
Threadripper 1920x
128GB RAM
RTX 3060 TI
spartan00j
Postby face_off » Mon Oct 03, 2022 11:34 pm
face_off Mon Oct 03, 2022 11:34 pm
Hi.
Can you please send me the scene that causes this issue?
Postby spartan00j » Tue Oct 04, 2022 3:56 pm
spartan00j Tue Oct 04, 2022 3:56 pm
face_off wrote:Hi.
Here you go.
Untitled.zip
(9.75 MiB) Downloaded 172 times
Win 10
Threadripper 1920x
128GB RAM
RTX 3060 TI
spartan00j
Postby face_off » Tue Oct 04, 2022 11:28 pm
face_off Tue Oct 04, 2022 11:28 pm
That scene animation renders fine for me - no skipped frames.
Is it possible your system is rendering the frame so quickly that the plugin is incorrectly detected the end of the frame? If you set the Max Samples to 100 does it help?
Are you network rendering? If so, does turning off network rendering fix the problem?
Postby spartan00j » Wed Oct 05, 2022 12:45 am
spartan00j Wed Oct 05, 2022 12:45 am
face_off wrote:Thanks
Actually I thought I was rendering too fast at one point as well. But I adjusted the frames up to 500 at one point. Got the same results.
And also no I do not use Network rendering.
I tried resetting my default startup scene to the fault. And having the default figure in the same. And I Get the same results.
Win 10
Threadripper 1920x
128GB RAM
RTX 3060 TI
spartan00j
Postby face_off » Wed Oct 05, 2022 1:25 am
face_off Wed Oct 05, 2022 1:25 am
Are you saving to an SSD or hard drive please?
Postby spartan00j » Wed Oct 05, 2022 1:27 am
spartan00j Wed Oct 05, 2022 1:27 am
face_off wrote:Are you saving to an SSD or hard drive please?
My main drive and what I'm saving it to is a m.2 SSD.
Win 10
Threadripper 1920x
128GB RAM
RTX 3060 TI
spartan00j
Postby face_off » Thu Oct 06, 2022 6:25 am
face_off Thu Oct 06, 2022 6:25 am
Are you able to send me your config.xml file pls?
Next
Return to Poser
Users browsing this forum: No registered users and 14 guests
Fri Apr 19, 2024 6:49 am [ UTC ]
