How to set up a PBR material in Octane poser plugin?
Forums: How to set up a PBR material in Octane poser plugin?
Postby gsfcreator » Tue Sep 28, 2021 3:17 pm
gsfcreator Tue Sep 28, 2021 3:17 pm
Hello there!
I know that octane is supporting PBR, and I wish to learn how to set up such materials within the plugin. I saw this old video made by Paul:
https://www.youtube.com/watch?v=UwPthyr ... aulKinnane
I understand that the answer for what I seek lays within this graph node option, but I have no idea where to begin. is there any thorough guide that you people can link me to? thanks in advance <3
Core I7-8700K, 32RAM, GTX1080Ti, win10
gsfcreator
Re: How to set up a PBR material in Octane poser plugin?
Postby face_off » Tue Sep 28, 2021 11:22 pm
face_off Tue Sep 28, 2021 11:22 pm
Hi. In general, you would use the Octane Universal Material for PBR. https://docs.otoy.com/StandaloneH_STA/StandaloneManual.htm#StandaloneSTA/UniversalMaterial.htm?Highlight=pbr
Postby gsfcreator » Wed Sep 29, 2021 1:16 pm
gsfcreator Wed Sep 29, 2021 1:16 pm
face_off wrote:Hi. In general, you would use the Octane Universal Material for PBR. https://docs.otoy.com/StandaloneH_STA/StandaloneManual.htm#StandaloneSTA/UniversalMaterial.htm?Highlight=pbr
thank you, Paul! I'm also trying to figure out how to add "Tiling" Normal maps and detail maps to another material. is that doable with the octane plugin?
gsfcreator
Postby face_off » Thu Sep 30, 2021 9:52 am
face_off Thu Sep 30, 2021 9:52 am
Yes, this should be doable. There is information here in the forums on how to use normal maps.
Postby gsfcreator » Thu Sep 30, 2021 12:48 pm
gsfcreator Thu Sep 30, 2021 12:48 pm
thanks, Paul. I did a search and couldn't find anything. I'll search again later. is it okay if I'll open a new post with this question?
gsfcreator
Postby face_off » Thu Sep 30, 2021 11:05 pm
face_off Thu Sep 30, 2021 11:05 pm
As this is a general Octane question, and not related to the plugin, I suggest searching and posting in the General Discussion forum.
Postby gsfcreator » Fri Oct 01, 2021 10:17 am
gsfcreator Fri Oct 01, 2021 10:17 am
Do you mean that I'll have to do this outside of the plugin? because I'm using only the poser plugin, not the stand-alone...
gsfcreator
Postby galleon27 » Fri Oct 01, 2021 11:42 am
galleon27 Fri Oct 01, 2021 11:42 am
gsfcreator wrote:Do you mean that I'll have to do this outside of the plugin? because I'm using only the poser plugin, not the stand-alone...
He means that you can ask or search in the General Discussion forum since creating materials is the same in every single plugin. And not just creating materials. Everything is pretty much the same across the board. The only difference is the host application. So if you have any question regarding workflow, ask in General Discussion or search how its done in another plugin if you can't find an answer.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
galleon27
Postby gsfcreator » Sat Oct 02, 2021 8:00 am
gsfcreator Sat Oct 02, 2021 8:00 am
Thanks, I'll post on the general forum and see how to progress from there.
gsfcreator
Return to Poser
Tue Apr 16, 2024 2:00 pm [ UTC ]
