OctaneRender 4 for DAZ Studio [obsolete]
Posted: Tue Oct 23, 2018 11:22 am
Pls read http://poserphysics.blogspot.com.au/2016/03/before-you-submit-octane-support.html prior to posting support issues.
NOTE 1: For users who experience a DAZStudio crash - deleting C:\Users\[username]\OctaneRender\Data\OctaneRender_settings.oczdb may resolve the issue.
NOTE 2: For users having an issue where the Save button is disabled if using the Final button - disable the Final button and in Render settings select the SuperScope (2:1) Size / aspect ratio and drag the Viewport height or width until you reach required resolution.
NOTE 3: For users having an issue where rendering an animation fails after 11 frames - make sure the DAZStudio viewport is visible when you render the animation.
NOTE 4: If Octane materials are not loading when you load a previously saved scene - tick Preferences->Load OctaneRender materials from .duf user presets. If ticking this option does not stick between DAZStudio restarts, delete OctaneRender_settings.oczdb as per NOTE 1 above.
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender 4 for DAZ Studio - TEST (ie. pre-release) and STABLE releases.
DAZ Studio Version
DAZ Studio 4.8 or later on Window Vista, 7, 8 or 10 64bit
Nvidia Driver Version
Nvidia drivers 392.x or later
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
- Operating System (ie. Win XP, Vista, 7, 8)
- Amount of RAM
- Nvidia driver version
- DAZ Studio version
- OctaneRender for DAZ Studio version (ie. 2.24.2.1)
- The most important part of resolving a problem is me being able to re-produce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
Download Links
Latest TEST build (Octane 4.00 RC6)
- Regular - OctaneRender for DAZ Studio 4.00.0.40 (64 bit) UPDATED
- Subscription - Not yet available
Release Notes
4.00.0.40 (23-Oct-2018)
- Compiled with Octane 4.00 RC6
- Removed the GPU Throttling option
- Removed the Restart Driver option
- Added Open Device Settings button to the System tab
- Added Denoiser pins to the Imager Settings. Enabling Denoising then enabled the viewing of the De Main render pass (once the denoising pass has commenced)0
- Kernel->Light ID's are not working correctly
- Added additional Octane 4.00 render passes
- Added Kernel AI Light options
DAZ Studio Version
Network Rendering
- Amount of RAM
Download Links
Release Notes
