How to create a ground shadow under HDRI lighting
Forums: How to create a ground shadow under HDRI lighting
DAZ Studio (Export Script Plugin developed by Tugpsx; Integrated Plugin maintained by Paul Kinnane)
Postby frewinhu » Thu May 10, 2018 12:17 am
frewinhu Thu May 10, 2018 12:17 am
Is there a way to create a nice cast shadow on the ground of the HDRI image used in the Octane plugin for daz?
frewinhu
Re: How to create a ground shadow under HDRI lighting
Postby face_off » Thu May 10, 2018 1:05 am
face_off Thu May 10, 2018 1:05 am
Add a plane at the figure's feet to act as the ground and the shadow should automatically render. You need to ensure you are using a HDR image and not a LDR image in order for the sun to be bright enough to cast a shadow.
Postby valzheimer » Mon May 14, 2018 4:16 am
valzheimer Mon May 14, 2018 4:16 am
If you don't have a scene ground/or want only HDRI and a model, just generate a plane from primitives in DS, Create New Primitive>Plane,
then set the plane to diffuse material and activate "shadow catcher", it will act as an invisible floor giving you a shadow cast.
valzheimer
Return to DAZ Studio
Mon Feb 18, 2019 9:51 am [ UTC ]
