Problem Rendering with 2 GTX Titan X (SLI) - White material
Forums: Problem Rendering with 2 GTX Titan X (SLI) - White material
Moderator: BK
Postby Veneris » Fri Mar 03, 2017 2:58 am
Veneris Fri Mar 03, 2017 2:58 am
I'm trying to do SLI for the first time with 2 GXT TITAN X in Octane Render for DAZ Studio. The plugin does recognize the two cards, but at the moment of rendering ... the material of any object appears blank. Why? What I have to do?
Trying with IRAY this goes well.
Image Image Image Image
Upgrade:
Also happens the same rendering with a single gtx titan x card, I think it has to do with the drivers of the cards I just updated to version 378.66.
Intel Core i7-5820k, 16.0GB RAM, 2 NVIDIA GeForce GTX TITAN X. Windows 10 (64 bits)
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
Veneris
Re: Problem Rendering with 2 GTX Titan X (SLI) - White material
Postby calus » Fri Mar 03, 2017 3:44 am
calus Fri Mar 03, 2017 3:44 am
Veneris wrote:I'm trying to do SLI for the first time with 2 GXT TITAN X in Octane Render for DAZ Studio. The plugin does recognize the two cards, but at the moment of rendering ... the material of any object appears blank. Why? What I have to do?
From DAZ FAQ:
SLI needs to be turned off in order to take full advantage of multi-GPU setups. OctaneRender performance will perfectly scale with as much Nvidia GPUs are installed in the system.
https://docs.otoy.com/#daz-studio-v2-introduction-faq
Pascal ANDRE
calus
Postby Veneris » Fri Mar 03, 2017 4:08 am
Veneris Fri Mar 03, 2017 4:08 am
From DAZ FAQ:
I did what you recommend and everything stays the same. See picture 5, the materials do not load. I'm using a GTX TITAN X and it's still the same.
Veneris
Postby Veneris » Fri Mar 03, 2017 4:24 am
Veneris Fri Mar 03, 2017 4:24 am
Problem solved I have to activate this option.
Veneris
Postby face_off » Fri Mar 03, 2017 6:19 am
face_off Fri Mar 03, 2017 6:19 am
You need to enable the option below it too. If the checkbox tick status is not retained between DAZStudio sessions, check out question 8) at https://docs.otoy.com/manuals/products/daz-studio/v3/introduction/faq/.
Postby Veneris » Sat Mar 04, 2017 12:38 am
Veneris Sat Mar 04, 2017 12:38 am
I just realized that, thanks.
Veneris
Postby Veneris » Thu Mar 30, 2017 5:53 am
Veneris Thu Mar 30, 2017 5:53 am
Hi, every time I open DAZ Studio or any saved scene, these options marked in red are not selected. Is there any way they will always be marked? I already tried the reset button plugin, but it does not work.
Veneris
Postby face_off » Thu Mar 30, 2017 6:10 am
face_off Thu Mar 30, 2017 6:10 am
Did you follow the FAQ link I posted above?
Postby Veneris » Fri Mar 31, 2017 12:38 am
Veneris Fri Mar 31, 2017 12:38 am
Thank you! problem solved. Yes, I had gone to that link, but I only read information related to SLI, I did not read below, sorry.
Veneris
Return to DAZ Studio
Users browsing this forum: No registered users and 20 guests
Sat Apr 20, 2024 1:59 am [ UTC ]
