For Users Experiencing Hangs When Downloading LiveDb Mats
Forums: For Users Experiencing Hangs When Downloading LiveDb Mats
Moderator: BK
Postby face_off » Mon Jan 23, 2017 5:24 am
face_off Mon Jan 23, 2017 5:24 am
To debug this issue, create a file C:\Program Files\DAZ 3D\DAZStudio4\octane_log_flags.txt and set it's contents to:
logToFile
logPrefix
logTime
logFlushTime 100
logForceFlush
liveDBDebugging
Now run DAZStudio as Administrator. If you experience a hang or lockup when downloading from the LiveDb, paste the C:\Program Files\DAZ 3D\DAZStudio4\octane_log.txt file in this thread. You must be running DAZStudio as Administrator in order for the octane_log.txt file to be created.
You need to have installed plugin version 3.5.3.30 or later when doing the above.
Re: For Users Experiencing Hangs When Downloadi LiveDb Materials
Postby Laticis » Mon Jan 23, 2017 9:58 am
Laticis Mon Jan 23, 2017 9:58 am
Thank you very much for the heads up :)
Laticis
Postby mlru » Sat Jan 28, 2017 6:14 pm
mlru Sat Jan 28, 2017 6:14 pm
It didn't work with version 3.4.5.29, but it did with 3.5.3.30. :)
Tested with "metal dirt v3 (2)"
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
mlru
Postby Leonides02 » Fri Feb 10, 2017 7:33 am
Leonides02 Fri Feb 10, 2017 7:33 am
Hi Paul,
You may have found a solution. After upgrading to 3.5 and running in Administrator mode, I've had absolutely no problems downloading from the LiveDB! :D
Leonides02
Re: For Users Experiencing Hangs When Downloading LiveDb Mats
Postby Mirana » Sun Jun 04, 2017 9:37 am
Mirana Sun Jun 04, 2017 9:37 am
Hate this bug. File attached
octane_log.txt
(188.54 KiB) Downloaded 610 times
Mirana
Postby face_off » Sun Jun 04, 2017 10:39 am
face_off Sun Jun 04, 2017 10:39 am
May I suggest updating to the latest version of the plugin, where this problem appears to have been resolved.
Postby Mirana » Mon Jun 05, 2017 9:38 am
Mirana Mon Jun 05, 2017 9:38 am
Awesome, thanks
Mirana
Postby RGUS » Sun Oct 01, 2017 12:58 pm
RGUS Sun Oct 01, 2017 12:58 pm
Hi Paul,
Attached is the octane_log.txt file created after running as administrator and with octane_log_flags.txt created in "C:\Program Files\DAZStudio4"
Trying to load "glass, fake falloff from LiveDB
Hope this is correct and helps isolate the issue.
octane_log.txt
(1021 Bytes) Downloaded 522 times
RAM: 64GB
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
RGUS
Postby face_off » Mon Oct 02, 2017 12:44 am
face_off Mon Oct 02, 2017 12:44 am
Thanks Deane. I was able to successfully download that material using the plugin. May I suggest trying to download it in Octane Standalone, and if that works, try again with the plugin. Let me know how you go. In the meantime I will submit the log to Otoy.
Postby RGUS » Mon Oct 02, 2017 4:31 am
RGUS Mon Oct 02, 2017 4:31 am
Hmmmmm ... standalone, I was able to load the material, then in Studio it loaded ok... but... I don't know why.
RAM: 64GB
RGUS
Next
Return to DAZ Studio
Users browsing this forum: No registered users and 13 guests
Fri Apr 19, 2024 10:22 am [ UTC ]
