OcDS - Custom UI for DAZ Studio 4.9
Forums: OcDS - Custom UI for DAZ Studio 4.9
DAZ Studio (Export Script Plugin developed by Tugpsx; Integrated Plugin maintained by Paul Kinnane)
Postby linvanchene » Mon May 02, 2016 8:09 am
linvanchene Mon May 02, 2016 8:09 am
I put together a new custom UI for Daz Studio Pro BETA - version 4.9.2.44.
That Beta version has a new pane called Install.
namffuak shared the idea to actually place the Install pane next to the viewport in the middle area.
-> That way the window with all the products is now quite large and it is more conveniant to browse and find products.
Activity 1 is the Install pane
Activity 2 is Scene setup
Activity 3 OctaneRender
then some other Activities for Iray, Animation, LAMH, Dynamic Clothing, Content Editing and Various.
-> If you do not own some of the plugins the corresponding panes will simply be left out while the rest of the UI remains the same.
This means if you use the UI with older versions than Daz Studio Pro BETA - version 4.9.2.44. the Install pane will be missing.
You can of course always add it manually later when you upgrade to a newer version.
If anyone wants to start building their own Custom UI version based on this:
I attached a .zip with the folders user styles and user layouts and some more preview screenshots.
20160502 DS 4.9 Custom UI.zip
.zip with folder user layouts and user styles
(3.47 MiB) Downloaded 956 times
1) Just drop the folders user styles and user layouts into
C:\Users\USERNAME\AppData\Roaming\DAZ 3D\Studio4 Public Build
or
2) Make sure to save your own existing custom UI layout before proceeding so you can revert back if needed
3) then select the layout "20160502 lin DS 4.9" from Window - Workspace - Select Layout...
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
linvanchene
Re: OcDS - Custom UI for DAZ Studio 4.9
Postby face_off » Mon May 02, 2016 9:40 am
face_off Mon May 02, 2016 9:40 am
Great work! Stickied.
Postby Notiusweb » Wed May 11, 2016 3:06 am
Notiusweb Wed May 11, 2016 3:06 am
Linvanchene, is that a direct export to Photoshop with Daz, how do you like using that? Does it work somehow with the OcDS plugin also?
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Notiusweb
Postby linvanchene » Wed May 11, 2016 10:29 am
linvanchene Wed May 11, 2016 10:29 am
Notiusweb wrote:Linvanchene, is that a direct export to Photoshop with Daz, how do you like using that? Does it work somehow with the OcDS plugin also?
Placed an overview of different DAZ Studio and OctaneRender to Photoshop bridges in another thread:
viewtopic.php?f=40&t=53944&p=273325#p273325
linvanchene
Postby linvanchene » Fri May 13, 2016 3:19 pm
linvanchene Fri May 13, 2016 3:19 pm
Updated version:
20160514 DS 4.9 Custom UI v1003
- placing the "Shader Mixer" pane next to the viewport pane caused the viewport pane not to snap properly to the UI borders and scale properly with the open tabs
-> moved "Shader Mixer" and "Shader Builder" panes to the "Various" activity to prevent interference with standard workflows that depend on proper viewport scaling
20160514 DS 4.9 Custom UI v1003.zip
(227.67 KiB) Downloaded 807 times
linvanchene
Postby Tugpsx » Sat May 14, 2016 2:15 pm
Tugpsx Sat May 14, 2016 2:15 pm
Thanks for all your work, this is a needed add-on for Daz Studio Ver. 4.9. I like what you have done thus far and will play around with your customizations.
Thanks for sharing.
Dell Win Vista 32 | NVIDIA Quadro NVS135M | Core2 Duo T7500 2.20GHz | 4GB
CyberPowerPC Win 7 64| NVIDIA GTX660Ti (3G) GTX480(1.5G) | 16GB
Tugpsx
Return to DAZ Studio
Users browsing this forum: No registered users and 5 guests
Thu Sep 24, 2020 12:06 pm [ UTC ]
