Bug with base geometries and clay rendering on plugin start
Forums: Bug with base geometries and clay rendering on plugin start
DAZ Studio (Export Script Plugin developed by Tugpsx; Integrated Plugin maintained by Paul Kinnane)
Postby larsmidnatt » Sun Mar 31, 2013 3:50 pm
larsmidnatt Sun Mar 31, 2013 3:50 pm
When I start the plugin there are two things I have to do each time: click the clay rendering button twice and checking and unchecking the "use base geometries" button.
When I start the plugin it seems defaulted to clay rendering mode. When you click the clay rendering button the render seems to restart and the button indication changes. But it's still rendering clay. So I click it once more and then it actually loads the materials.
Also the rendering always defaults to rendering in base resolution, even if you unchecked it in the past! So you have to click the button and unclick it to trick the system into doing what you want.
Win10 x64 i7 4770K 32GB
1070 8GB + 1060 3GB
DS 4.10 OcDS Latest
larsmidnatt
Re: Bug with base geometries and clay rendering on plugin st
Postby t_3 » Sun Mar 31, 2013 3:54 pm
t_3 Sun Mar 31, 2013 3:54 pm
larsmidnatt wrote:When I start the plugin there are two things I have to do each time: click the clay rendering button twice and checking and unchecking the "use base geometries" button.
confirmed - a fix is being worked on...
t_3
Return to DAZ Studio
Sun Sep 27, 2020 11:34 pm [ UTC ]
