Mesh smoothing problems
Forums: Mesh smoothing problems
DAZ Studio (Export Script Plugin developed by Tugpsx; Integrated Plugin maintained by Paul Kinnane)
Postby itou31 » Thu Mar 28, 2013 8:42 am
itou31 Thu Mar 28, 2013 8:42 am
Just purchased also and just made a test with simple figure V5 (default).
But I have some probleme on smoothing and shadow with default daylight.
I test to apply smooth modifier, but no result, increase subdiv ? no result also.
How do you get smooth figure from default ? very noticing on the ear.
I have no enough time to test now but will check it again tomorrow.
thanks.
For the first approach, I was a bit disapointed :| . Exporting to standalone get better result by default.
But I think that I have some wrong settings !
Thanks for the plugin t_3.
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
itou31
Re: Introducing the Octane for DAZ Studio plug-in
Postby Isotemod » Thu Mar 28, 2013 12:28 pm
Isotemod Thu Mar 28, 2013 12:28 pm
itou31 wrote:Hi,
thanks.
Theres currently a bug that seems to start the plugin as if the use base geomtries for rendering (in preferences tab) is selected.
First toggle this on and off to see if the Daz sub division kicks in.
There are other things that may make smooth surfaces appear to cause unsmoothed shadows on themselves (most commonly on Genesis bent geometry like knees,elbows and shoulders)
Things to watch out for
BUMP - One setting does not fit all make sure you have it set as low as needed to achieve the effect and match it with your camera distance. If you don't need it turn it to off images will clear faster and often you can't tell the difference.
High bump settings will artificially increase this effect with some lighting conditions
RAYEPSILON - The majority of the time you will have this set on 0. In some cases for smoother shadows in some lighting conditions you will want to increase this slightly to as much as 0.0005. Doing this has a side effect of making intersecting geometry including invisible trasparency mapped objects create a visible black mark at the point of intersection.
99.9 percent of the time these things won't cause an issue but you can tweak them away.
Isotemod
Postby itou31 » Thu Mar 28, 2013 9:02 pm
itou31 Thu Mar 28, 2013 9:02 pm
Thanks for pointing me to this. The figure is smooth now.
I'm going to explore the plugin...
itou31
Return to DAZ Studio
Users browsing this forum: No registered users and 5 guests
Sun Sep 27, 2020 4:40 pm [ UTC ]
