The plugin was built with SR15 - is that available to you?Rhino 6 SR14
I think I have probably built the plugin with the latest SR Candidate of Rhino. I will rebuild and post here for you to test.No...it's strange...
Can you provide a .3dm which exhibits this problem please?the new version has some problems.
The projects have no materials applied to the objects. All the scene is grey, hdri seems not to be applied. Live updated are not checked. Exposure has not the original value..and so on. All the scene seems to be reset
Hi Fabrizio. Thanks for sending through the scene. There is indeed definitely a problem there. If you Start Rhino, Load you scene, start rendering, then load your scene again, it appears to be OK. But I will try to get a fix released ASAP.The projects have no materials applied to the objects. All the scene is grey, hdri seems not to be applied. Live updated are not checked. Exposure has not the original value..and so on. All the scene seems to be reset
