Octane Rhino Crash with high resolution rendering
Forums: Octane Rhino Crash with high resolution rendering
Postby slimer » Fri Jan 11, 2019 4:03 am
slimer Fri Jan 11, 2019 4:03 am
Hello,
I am currently running Rhino 6 latest, Octane 3.085 with the Nvidia 417 drivers.
I was rendering with 6000x10000 pixel and it was fine. But when I move it up to 8000x10000 pixels it crashes with the below error message;
And once it crashes, no matter how low a resolution you set it will keep crashing.
I have tried this on both 3.083 and 3.085, no difference. I am rendering with a gtx970 and a gtx1070, I have tried to turn off the 970 but makes no difference.
Any ideas?
slimer
Re: Octane Rhino Crash with high resolution rendering
Postby slimer » Fri Jan 11, 2019 4:30 am
slimer Fri Jan 11, 2019 4:30 am
[Update]
Just tried again and found out that it works up to 6700 x 10000 pixel and it works fine. A total pixel of 67000000.
From that I tried 8000 x 8375 with a total pixel count of 67000000 and it still work. But when I tried to up the resolution to 8000 x 8500 it crashes.
Does it have a pixel limit between 67M to 68M pixels?
I tried turning on both cards and it makes no difference so it was not a problem created by my hardware.
slimer
Postby face_off » Fri Jan 11, 2019 10:35 am
face_off Fri Jan 11, 2019 10:35 am
I was able to reproduce your error, and it was a memory problem. I have resolved that problem, but hit a new limit of approx 15k x 10k, which is a limit imposed by the Windows bitmap maximum size. This change will be in the next release of the plugin.
Postby slimer » Fri Jan 11, 2019 10:46 am
slimer Fri Jan 11, 2019 10:46 am
Thanks, Paul.
Can you also adjust the limit of the slider as well as this is very confusing.
If this is a Windows bitmap memory issue then why does Octane allow people to render 65K x 65K on the slider?
Thanks again.
slimer
Postby face_off » Fri Jan 11, 2019 10:55 am
face_off Fri Jan 11, 2019 10:55 am
There is now a popup msg if there is insufficient RAM to paint the rendered image onto the Viewport.
The Rhino plugin has C# component that runs as a Rhino plugin, and a C++ component that interfaces with Octane, and it's the transferral of the rendered image from the C++ component to the C# component that is failing due to the Windows API not being able to create a large enough bitmap. If you have more than 16GB RAM you may find you can render much larger resolutions - but I'm not sure.
Postby slimer » Fri Jan 11, 2019 4:57 pm
slimer Fri Jan 11, 2019 4:57 pm
"The Rhino plugin has C# component that runs as a Rhino plugin, and a C++ component that interfaces with Octane, and it's the transferral of the rendered image from the C++ component to the C# component that is failing due to the Windows API not being able to create a large enough bitmap. If you have more than 16GB RAM you may find you can render much larger resolutions - but I'm not sure."
I have tried the same file on a machine with 32GB of RAM and 4X GTX 1080 Ti, it still failed. Same as the one with 16GB of RAM.
slimer
Postby face_off » Sat Jan 12, 2019 12:31 am
face_off Sat Jan 12, 2019 12:31 am
You need to next release (not yet available) to test this properly.
Return to Rhinoceros 3D
Sat Feb 22, 2020 4:08 am [ UTC ]
