Page 1 of 2
From rhino material to octanematerial
Posted:
Fri Nov 02, 2018 9:25 am
by fabrizio_s
is there a way to transform rhino materials to octane materials?
bye
Re: From rhino material to octanematerial
Posted:
Sun Nov 04, 2018 10:22 am
by face_off
Hi Fabrizio
Rightclick the Rhino material in the Material tab->Change Type to Octane material.
Or you can convert all Rhino materials to Octane materials with the Setup tree rightclick menu->Convert All Rhino Materials to Octane Materials.
Posted:
Sun Nov 04, 2018 4:38 pm
by fabrizio_s
Hi Paul,
I can't find it. Am I looking for it in the wrong place?
Posted:
Mon Nov 05, 2018 1:58 pm
by Bendbox
Hi Fabrizio,
I'm assuming you're in Rhino 6 if you don't see it on the right click. If so, it's located here under the main material editor. Just click on the pull down menu and select "Octane Material" and it will change the Rhino material to an Octane material.
Also, one other note . . . if you decide to convert all materials to octane materials by right clicking in the Octane Settings tree, the only materials it will convert are ones that are used. Just FYI.
Posted:
Mon Nov 05, 2018 6:46 pm
by fabrizio_s
thanx!
Posted:
Wed Aug 21, 2019 9:11 am
by frisog
Hi there, when I try to convert a materials with the 2 options available, all the material colors and textures are lost.. is this a know issue? (transparency is converted correctly)
This is with the newest Rhino and newest Octane plugin (4.5.0.111) for Rhino 6 (Version 6 SR17 - (6.17.19218.13231, 08/06/2019).
Posted:
Wed Aug 21, 2019 10:00 am
by face_off
I don't completely understand what you are saying. Can you provide some screenshots of the problem please?
Posted:
Mon Aug 26, 2019 8:19 am
by frisog
Sure. See attached image with explanation in the image.
Posted:
Tue Aug 27, 2019 11:02 am
by frisog
Hi Paul, any idea on the what the issue could be?
Posted:
Wed Aug 28, 2019 1:52 am
by face_off
Hi. I just tested this, and changing the type via the material combo box, and using the Convert All Materials To Octane Materials resulted in the same material conversion, so it is working correctly for me. I notice on your screenshot there are no texturemaps, so there are no maps to convert to the Octane material. If you have a specific material which demonstrates the problem you are having, can you please send it to me and I will take a closer look.
