server busy lock up with texture relink
Forums: server busy lock up with texture relink
Postby alfabruce » Sun Mar 11, 2018 10:02 pm
alfabruce Sun Mar 11, 2018 10:02 pm
Hi everyone,
Im getting this everytime I try to open some older files. It doesn’t happen on the newer ones.
I just locks up with this on the screen and there is nothing I can do but shut down and start again.
Rather frustrating as there is a lot of work I cant access at the moment.
Ive read about this in other areas and ive tried doing as they suggest but its not working.
Any ideas?
Cheers
Tim
alfabruce
Re: server busy lock up with texture relink
Postby face_off » Sun Mar 11, 2018 10:28 pm
face_off Sun Mar 11, 2018 10:28 pm
Try turning off Rhino Updates.
Postby alfabruce » Sun Mar 11, 2018 10:47 pm
alfabruce Sun Mar 11, 2018 10:47 pm
Hi Paul,
Yeah ive done that and it seemed to make difference on the newer files but not on the older ones.
Ive also removed the splash screen but still no luck.
Cheers
Tim
alfabruce
Postby face_off » Sun Mar 11, 2018 11:38 pm
face_off Sun Mar 11, 2018 11:38 pm
What about if you click "Switch To" or "Retry"?
Does Task Manager report an app with high CPU use?
Are you able to send me an older file where this occurs pls?
Postby alfabruce » Mon Mar 12, 2018 4:10 am
alfabruce Mon Mar 12, 2018 4:10 am
HI yeah ive tried the switching to etc and it just jams up and there is no way out of it.
Ive tried starting in safe mode and it warns about plugin bugs etc and if i say yes then there are a heap or warnings like the one attahed (all different and there were at leat 20 i clicked thorugh before I got bored.
Ill send you a file now.
Nah the task manager doesnt really show anything but Ill check again.
Cheers
Tim
alfabruce
Postby alfabruce » Mon Mar 12, 2018 4:32 am
alfabruce Mon Mar 12, 2018 4:32 am
Hi Paul I tried to send you a PM but it wouldnt allow it so ive tried to attach the file here but it says extension 3dm is not allowed.
alfabruce
Postby alfabruce » Mon Mar 12, 2018 4:36 am
alfabruce Mon Mar 12, 2018 4:36 am
Sent you an email.
Cheers
Tim
alfabruce
Postby alfabruce » Fri Jan 10, 2020 8:52 pm
alfabruce Fri Jan 10, 2020 8:52 pm
Hi Paul,
Im getting this problem again.
Any ideas. I dontthink it was successfully resolved last time.
Cheers
Tim
alfabruce
Postby face_off » Sun Jan 12, 2020 11:01 am
face_off Sun Jan 12, 2020 11:01 am
Hi Tim. When this previously occurred to you I suggested you delete the config.xml file, but I never heard back from you with if it worked or now.
Return to Rhinoceros 3D
Users browsing this forum: Bing [Bot], FanzunAG and 1 guest
Mon Mar 30, 2020 8:23 am [ UTC ]
