Problem loading the plugin
Forums: Problem loading the plugin
Postby sgufa » Wed Apr 12, 2017 12:04 pm
sgufa Wed Apr 12, 2017 12:04 pm
Hi there,
from a little time I am having problems every time I open a scene.
The plugin does not load and I am forced to create a new empty scene, then copy and paste the other scene to use octane. But once saved, when I open the problem occurs again and I have to repeat the same steps.
If I try to install another version of the plugin it always fails, but if I do it with an empty scene it does not give me problems.
What could be the cause?
sgufa
Re: Problem loading the plugin
Postby face_off » Wed Apr 12, 2017 1:56 pm
face_off Wed Apr 12, 2017 1:56 pm
Hi - the plugin should load when Rhino starts up. Have you tried starting Rhino (which should cause the plugin to load) and then loading your scene? Do not double-click your .3dm file, since Rhino does not load some plugins when you do this.
Postby sgufa » Thu Apr 13, 2017 11:41 am
sgufa Thu Apr 13, 2017 11:41 am
face_off wrote:Hi - the plugin should load when Rhino starts up. Have you tried starting Rhino (which should cause the plugin to load) and then loading your scene? Do not double-click your .3dm file, since Rhino does not load some plugins when you do this.
Ok, this way works. But until some time ago I could easily double-click the file and the plugin loaded successfully. Why this change?
Anyway, thank you very much Paul! :)
sgufa
Postby face_off » Thu Apr 13, 2017 12:06 pm
face_off Thu Apr 13, 2017 12:06 pm
I'm not sure. And the McNeel forums appear to be down at the moment, but I will ask the Rhino devs when I can.
Postby sgufa » Thu Apr 13, 2017 1:29 pm
sgufa Thu Apr 13, 2017 1:29 pm
Thank you for your time Paul.
sgufa
Postby face_off » Sun Apr 16, 2017 3:40 am
face_off Sun Apr 16, 2017 3:40 am
Pls see question 15 at https://docs.otoy.com/?manual=manuals/products/rhino/v3/faq/#rhino-v3-faq.
Postby sgufa » Wed Apr 19, 2017 4:47 pm
sgufa Wed Apr 19, 2017 4:47 pm
That was the problem!!! I just didn't notice it until now :o
Thanks Paul, now I open everything correctly ;)
sgufa
Return to Rhinoceros 3D
Fri Apr 19, 2024 7:55 pm [ UTC ]
