Controling the Export Tesselation of Geometry - how to?
Posted: Fri Feb 04, 2011 9:52 am
				Hi Sam,
I am running into an issue when I want to control the tesselation of surfaces.
First I thought that Rhino (5 WIP) just takes the current tesselation export settings that pop up before the standart obj export. But that is not the case. When I start the render out of Rhino the mesh is generated with an 'average' tesselation resolution.
The first thing to solve of course was to export the scene manually via the standart obj-exporter in Rhino and then replace the link in the mesh node inside octane but that is usually not working because of the auto scene scaling what is nessecary when you want to bring large scenes (milimeter units) to render properly in octane. So if you swap the mesh (in Octane) the camera looks somewhere else.
So is there a way to control the tesselation of geometry while using the Rhino2Octane export plugin?
Thank you for your help.
Refracty
Refracty
