OctaneRender 2022 for Rhino (TEST and STABLE)
Forums: OctaneRender 2022 for Rhino (TEST and STABLE)
Postby face_off » Mon Dec 05, 2022 6:41 am
face_off Mon Dec 05, 2022 6:41 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Rhino - TEST and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) Make sure you have the latest Rhino Service Release installed.
3) If you get an "Error Starting Octane - Could not load OctaneWrapper?.dll" error when installing the plugin, this is generally due to not having the latest NVIDIA drivers installed (so see Solution 1) above.
4) If you get a "Package not compatible" error when installing the plugin, please follow the instructions at https://wiki.mcneel.com/rhino/5/rhi-problems -> "Package not compatible".
5) If you get an "Unable to load OctaneRenderForRhino.rhp plugin: initialization failed" error when starting the plugin, delete the HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\6.0\Plug-Ins\F109BD23-4CF3-4C0B-9F83-06BE474B0152 and HKEY_LOCAL_MACHINE\Software\McNeel\Rhinoceros\6.0\Plug-Ins\F109BD23-4CF3-4C0B-9F83-06BE474B0152 registry entries using Regedit and then reinstall the plugin. If this does not resolve the problem, delete HKEY_CURRENT_USER\Software\McNeel\Rhinoceros from the registry and then reinstall the plugin.
6) If you get an "OctaneRender for Rhino not activated." error when rendering via the Rhino->Render->Render menu, open the plugin Setup window via the OctaneRenderForRhino command, or by adding the plugin panel to the Rhino Properties window as per https://docs.otoy.com/RhinoH/RhinoPluginManual.htm#Rhinoceros/InstallationofthePluginintoRhinoceros.htm.
7) Cuda error 999 - failed to load shader code: Multiple definition of 'cpSptStatistics' in 'cuda_teturemode' means that your plugin version is too old for the Nvidia drivers that are installed, so update to the latest version of the plugin
8) The Octane Viewport does not appear after clicking the Open Viewport button. This occurs when the Viewport was previous closed on a second monitor, or off the current screen. To resolve this, delete the plugin configuration file config.xml as per https://docs.otoy.com/RhinoH/RhinoPluginManual.htm#Rhinoceros/Configuration.htm.
9) LiveDb materials containing OSL nodes will not load into the plugin correctly. The plugin does not currently support OSL Projection or Texture nodes. Instead, copy these Livedb materials into the clipboard from Octane Standalone and paste them into a NodeGraph material in the plugin.
10) Where is the macOS version? I have done quite a lot of work investigating a macOS version of the plugin for Rhino. Unfortunately the macOS UI that Rhino uses offers far fewer controls than the Windows version, and I don't think it's possible to replicate the tree structure that the plugin uses in Windows. So I think it would require a complete re-write of the plugin in order for it to work on macOS, and I don't think that would be possible in the near future.
11) If when rendering with Octane 2021, the render appears to be using a different color map, set the Kernel->White Light Spectrum to Legacy/Flat to render as per Octane 2020.
12) Rhino locks-up/freezes when loading a .3dm containing Octane data. This is due to the plugin searching through very large (or invalid) folders searching for missing texturemaps. To resolve this, delete the plugin configuration file config.xml as per https://docs.otoy.com/RhinoH/RhinoPluginManual.htm#Rhinoceros/Configuration.htm.
Rhino Version
This version requires Rhino6, SR34 or later or Rhino 7 version 7.4.21078.1001 or later, on Windows. MacOSX is not currently supported.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 451 or higher.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Rhino version and build number
- OctaneRender for Rhino version (ie. 2.0.10.8)
For more information
- Watch Iceglance's quickstart tutorial http://render.otoy.com/forum/viewtopic.php?f=51&t=36299
- Read the on-line manual
- Watch the "Getting Started" video http://vimeo.com/73202740
- NodeGraph material tutorial - https://youtu.be/Yd7jkAnRZpg
- Shadow Passes tutorial - https://youtu.be/ozW98ZjeXYM
- Exporting from Bongo to Octane Standalone - https://vimeo.com/116603709
- Camera Motion Blur in OctaneRender for Rhino - https://vimeo.com/90721378
- Rhino HDRLS integration with OctaneRender - https://vimeo.com/104381431
- Post your question on this forum thread
- To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
Known Issues
- Prior to rendering a Sun Study, Flythru Animation or Bongo Animation, you must select the Perspective Viewport in Rhino that the animation uses
Download Links
NOTE: Rhino files saved with this version of the plugin may not open with the Octane 2021 or previous versions of the plugin.
Current TEST build (Octane 2021.1.1)
Previous STABLE build (Octane 2021.1)
Release Notes
2022.1.1.135 (7-Apr-2023)
- Compiled with Octane 2022.1.1
- Fixed issues which were preventing the plugin from running with Rhino8
- Internal changes designed to make having a Grasshopper interface possible
- Due to the above changes being somewhat experimental, I have not released a Rhino6 or Demo version for the release
2022.1.0.134 (6-Dec-2022)
- Fixed issue where the Network Rendering button was not available
2022.1.0.133 (5-Dec-2022)
- Implemented the Octane 2022.1 change "Image nodes now have a Border mode for U and V separately."
- Added Textures->Fields nodes
- Added C4D noise nodes
- Added Values->Utility nodes
- Added the Photon Tracing Kernel
- Added new Texture nodes from Octane 2022.1 XB2
- Added the Curvature Visibility property from Octane 2022.1 XB3
- Added new texture nodes from Octane 2022.1 XB4
- IMPORTANT: Octane 2022.1 changes the way the Daylight Environment renders, and changes the way volumes render, so old scene using either of these Octane features may render differently
Re: OctaneRender 2022 for Rhino (TEST and STABLE)
Postby Refracty » Mon Dec 05, 2022 9:33 am
Refracty Mon Dec 05, 2022 9:33 am
Thank you
Refracty
Postby Lekip » Mon Dec 05, 2022 4:43 pm
Lekip Mon Dec 05, 2022 4:43 pm
[FIXED] I can not access the Network Rendering menu as of right now. An error message comes up, telling me network rendering is not available in subscription or demo versions. We used to be enterprise customers (now studio+ i guess?) and rely on network rendering a fair bit. I always used to work with previous versions. Is this an issue with the plugin, or something on Otoy's end with the new tiers? Or did I miss something?
Nonetheless, thank you so much for getting this in our hands so fast!
EDIT: Apparently I am currently using a slave machine. However, I can't manage or steal devices from other machines due to the issue stated
Lekip
Postby v-cube » Mon Dec 05, 2022 5:32 pm
v-cube Mon Dec 05, 2022 5:32 pm
Thank you Paul!
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
v-cube
Postby face_off » Mon Dec 05, 2022 10:49 pm
face_off Mon Dec 05, 2022 10:49 pm
I have updated the installers at the top of this thread with:
2022.1.0.134
Postby face_off » Fri Apr 07, 2023 1:28 am
face_off Fri Apr 07, 2023 1:28 am
2022.1.1.135
Postby face_off » Wed Oct 18, 2023 12:48 am
face_off Wed Oct 18, 2023 12:48 am
I have posted a TEST version of the Octane 2023.1 version of the plugin at https://render.otoy.com/forum/viewtopic.php?f=41&t=82250&p=427547#p427547. There are no more planned releases of the Octane 2022.1 version of the plugin.
Return to Rhinoceros 3D
Users browsing this forum: No registered users and 18 guests
Thu Apr 25, 2024 11:23 am [ UTC ]
