Can you provide the .3dm file for this pls so I can test it?Gamma is set to 2.2, so I guess it's correct
fabrizio_s wrote:Has the material some reflections? I mean...maybe Visible Environment affects the color...
face_off wrote:Can you provide the .3dm file for this pls so I can test it?
If the Octane plugin is rendering the diffuse texture in the same way that Rhino does, then it seems it is working OK. If they were different, there would be a problem.You compared render with Rhino viewport if I'm correct and it's the same at my computer. The difference was between Rhino/Octane and jpg viewed on Windows image browser and other applications.
