OctaneRender 3 for Rhino (OBSOLETE)
Forums: OctaneRender 3 for Rhino (OBSOLETE)
Re: OctaneRender 3 for Rhino (TEST and STABLE)
Postby face_off » Wed Mar 21, 2018 2:08 am
face_off Wed Mar 21, 2018 2:08 am
Why is my node window so small??
when i mouse over the small window ans scroll, i can scroll all the parameter, but i can only see 1 line at a time.
It's a bit hard to help if you don't indicate if you are using Rhino5 or Rhino6. However it looks like maybe your Windows font is set to something which it effecting the panel layout.
Postby tomo8177 » Thu Mar 22, 2018 4:20 am
tomo8177 Thu Mar 22, 2018 4:20 am
i was running Rhino 6 on Windows 10.
this wasn't happening when i was using Rhino 5.
Changing the Windows Font didn't solve the problem for me...
tomo8177
Postby face_off » Fri Mar 23, 2018 11:48 am
face_off Fri Mar 23, 2018 11:48 am
What is your screen resolution set to pls? Are there any other Rhino panels which as not displaying correctly?
Postby tomo8177 » Sat Mar 24, 2018 3:28 am
tomo8177 Sat Mar 24, 2018 3:28 am
i am working with a laptop with 3840 x 2160 resolution, 64 bit Windows 10 machine.
with 200% text scale set by windows.
all other Rhino panels look fine.
the Octane setting panel looks okay, by the way.
tomo8177
Postby face_off » Sat Mar 24, 2018 10:58 pm
face_off Sat Mar 24, 2018 10:58 pm
Thanks. I will see if McNeel are able to help with this.
Postby franchais » Thu Apr 05, 2018 1:57 am
franchais Thu Apr 05, 2018 1:57 am
Hi Paul,
This tab keeps popping up when the live viewport is open.
K
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
franchais
Postby face_off » Thu Apr 05, 2018 4:16 am
face_off Thu Apr 05, 2018 4:16 am
This is fixed in the next release of the plugin (which I will try to get out in the next day or two).
Postby franchais » Thu Apr 05, 2018 5:07 am
franchais Thu Apr 05, 2018 5:07 am
Great thanks paul
franchais
Postby franchais » Fri Apr 13, 2018 12:21 am
franchais Fri Apr 13, 2018 12:21 am
Any updates on the next release?
franchais
Postby RizonParein » Tue Apr 17, 2018 9:08 pm
RizonParein Tue Apr 17, 2018 9:08 pm
Tried to install the plug in for a fresh installed Rhino 6 (latest version).
Tried the two last plug in versions, same error
RizonParein
PreviousNext
Return to Rhinoceros 3D
Users browsing this forum: No registered users and 16 guests
Sat Apr 20, 2024 12:42 am [ UTC ]
