Problems with instances
Forums: Problems with instances
Postby promity » Tue Jun 22, 2021 9:36 am
promity Tue Jun 22, 2021 9:36 am
Unfortunately, Octane often crashes if there are a large number of instances in the scene.
I have an insane amount of lamps in my restaurant scene, each of which has about 30 thousand polygons.
In total, these lights would weigh about a hundred million polygons, so I made them instances.
But with my attempts to add other objects through the instances, the LW crashes almost instantly when
starting the Octane render.
However, if I add these objects "physically", i.e. as pure geometry - Octane works well. But the scene gets really hard.
Maybe this problem is on the side of the LW?
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
Re: Problems with instances
Postby juanjgon » Tue Jun 22, 2021 5:45 pm
juanjgon Tue Jun 22, 2021 5:45 pm
I'm not sure, to be honest. Can you please enable the Octane log file to check if there is some kind of CUDA error before the crash? If you can reproduce this problem in a simple scene I could take a look at it here.
juanjgon
Postby promity » Wed Jun 23, 2021 2:39 am
promity Wed Jun 23, 2021 2:39 am
Unfortunately, the option to save the log file was disabled.
But I have known this situation for a long time - when Octane works better with large arrays of pure geometry, and with instances, the role of which is to relieve the scene from being overloaded with a large number of polygons, it is worse, or rather much less stable.
Lightwave 3d
promity
Postby pixym » Tue Jun 29, 2021 2:34 pm
pixym Tue Jun 29, 2021 2:34 pm
Hi, have you tried to simplify your 30000 polygons "lights" ?
To be honest so much polygons for a single light seems overkill for me.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - 32GB - 2 GTX 1080 TI - Win 10 64
NET RENDER : MB Biostar TB250-BTC Pro - Celeron 2C/2T - Open "Mining" Rig - 2 RTX 2080 TI - Win 7
pixym
Postby promity » Tue Jun 29, 2021 3:46 pm
promity Tue Jun 29, 2021 3:46 pm
This is a very complex lamp, with a hell of a lot of gold droplets inside. I converted these droplets into polygonal points and in the Layout through the plug-in assigned to these points the render as spheres. So I reduced the number of polygons several times, but the light is still quite heavy.
https://3ddd.ru/3dmodels/show/drop_shap ... amp_fial_b
Lightwave 3d
promity
Return to Lightwave 3D
Users browsing this forum: No registered users and 29 guests
Sat Apr 20, 2024 2:00 am [ UTC ]
