Crsh with Multthreaded scene extraction
Forums: Crsh with Multthreaded scene extraction
Postby tombosschaert » Fri May 07, 2021 12:00 pm
tombosschaert Fri May 07, 2021 12:00 pm
I have a LW crash with the latest version of the plugin when opening IPR. The crash disappears when I disable the new 'multithread scene extraction'.
I'll gladly send a packaged scene. It's pretty huge though. Where should I send it to?
tombosschaert
Re: Crsh with Multthreaded scene extraction
Postby juanjgon » Fri May 07, 2021 1:01 pm
juanjgon Fri May 07, 2021 1:01 pm
You are working with the 2020.2.3.1 plugin build, right? It has several fixes related to this feature.
You can send me the link to download the scene by pm ...
juanjgon
Postby tombosschaert » Fri May 07, 2021 3:21 pm
tombosschaert Fri May 07, 2021 3:21 pm
It is the latest version, but I am using 2019, because 2020 crashes with Octane material conversion, and it rotates my oriented instances 90 degrees.
I have also tested 2020, but that crashed as well.
I will send the scene through PM.
tombosschaert
Postby scooternva » Sat Jul 03, 2021 4:18 am
scooternva Sat Jul 03, 2021 4:18 am
FYI I have found that if NVLink is disabled multi-threaded scene extraction works. But if NVLink is enabled, kaboom.
Octane 2020.2.3.1 | LightWave 2019.1.5 (3134) | Win10 Pro 19041.1052 | 2 x Gigabyte AORUS RTX 2080 Ti Xtreme w/NVLink | Gigabyte AORUS Xtreme X399 | AMD Ryzen 2950X | 64 GB RAM | SSDs: Samsung 970 PRO 512 GB + Seagate FireCuda 510 2 TB | blog.gammans.zone
scooternva
Postby juanjgon » Sat Jul 03, 2021 5:10 pm
juanjgon Sat Jul 03, 2021 5:10 pm
scooternva wrote:FYI I have found that if NVLink is disabled multi-threaded scene extraction works. But if NVLink is enabled, kaboom.
Hmm, this makes no sense. The nvlink is a render option that has nothing to do with the scene extraction. It is something really weird. In any case if you have a scene that crashes at the extraction time it could be great to have it here to reproduce the problem.
juanjgon
Return to Lightwave 3D
Users browsing this forum: No registered users and 20 guests
Thu Apr 25, 2024 7:12 am [ UTC ]
