OctaneRender 2020.1 LightWave Beta build 2020.1.0.1
Forums: OctaneRender 2020.1 LightWave Beta build 2020.1.0.1
Re: OctaneRender 2020.1 LightWave Beta build 2020.1.0.1
Postby BorisGoreta » Wed Jan 15, 2020 12:27 pm
BorisGoreta Wed Jan 15, 2020 12:27 pm
Network rendering is not working properly, some of the quadrants in the final image are more noisier then others.
Original SSS medium does not produce same results as before.
BorisGoreta
Postby BorisGoreta » Wed Jan 15, 2020 4:07 pm
BorisGoreta Wed Jan 15, 2020 4:07 pm
Octane Vertex Attribute node works only if a weight map is named Weight !
BorisGoreta
Postby juanjgon » Wed Jan 15, 2020 4:16 pm
juanjgon Wed Jan 15, 2020 4:16 pm
BorisGoreta wrote:Octane Vertex Attribute node works only if a weight map is named Weight !
You can configure that from the object properties options, in the Attributes tab.
juanjgon
Postby BorisGoreta » Wed Jan 15, 2020 4:37 pm
BorisGoreta Wed Jan 15, 2020 4:37 pm
Thanks, I forgot about that part.
BorisGoreta
Postby Carlos3D » Tue Jan 21, 2020 10:55 pm
Carlos3D Tue Jan 21, 2020 10:55 pm
Hi Juanjo.
I found Bug in Edge Node in Octane.
When I add edge node on layout and set radius on 1 mm, go to Modeler with model and back to Loyout , ede radius to set 1m.
Thanks.
Carlos3D
Postby BorisGoreta » Wed Jan 22, 2020 12:15 am
BorisGoreta Wed Jan 22, 2020 12:15 am
+1
BorisGoreta
Postby Mastoy » Wed Jan 22, 2020 9:06 am
Mastoy Wed Jan 22, 2020 9:06 am
Carlos3D wrote:Hi Juanjo.
Thanks.
This bug is already in the 2019.1.5.0 version : viewtopic.php?f=36&t=73734
Mastoy
Postby Carlos3D » Thu Jan 23, 2020 7:06 pm
Carlos3D Thu Jan 23, 2020 7:06 pm
Thanks.
Yes, it is the same version!...
Carlos3D
Postby juanjgon » Thu Jan 23, 2020 9:16 pm
juanjgon Thu Jan 23, 2020 9:16 pm
Thanks.
Yes, sorry. There was a bug in the node file functions. It has been fixed for the next build.
juanjgon
Previous
Return to Lightwave 3D
Mon Feb 24, 2020 12:30 pm [ UTC ]
