Animating Instances
Forums: Animating Instances
Animating Instances
Postby Sinelab01 » Wed Sep 04, 2019 4:47 pm
Sinelab01 Wed Sep 04, 2019 4:47 pm
Hi, I'm animating instances on a surface by controlling the size by a null. I have a random texture on the instances but when I render the frames out the instances change color every frame, attached is my set up what am I doing wrong ?
Sinelab01
Re: Animating Instances
Postby juanjgon » Thu Sep 05, 2019 9:20 am
juanjgon Thu Sep 05, 2019 9:20 am
How are you rendering the scene, in update or full scene reload mode? This sounds like a scene full reload that is changing the instances IDs, or something like that.
If you want to share a scene with this problem, I could take a look at it here.
juanjgon
Postby Sinelab01 » Thu Sep 05, 2019 9:37 am
Sinelab01 Thu Sep 05, 2019 9:37 am
Thanks that would be great, I'll send you a file shortly.
Sinelab01
Postby juanjgon » Thu Sep 05, 2019 5:59 pm
juanjgon Thu Sep 05, 2019 5:59 pm
I've been checking your scene and I'm afraid that there isn't an easy solution to use the random texture with your instances. The problem is that the number of instances is not the same in all the frames, so after reloading the instancer for each frame, the IDs used to get the random texture change. Perhaps you could use a texture in world space to add the random appearance or something like that, but not the random texture node.
juanjgon
Postby promity » Fri Sep 06, 2019 6:37 am
promity Fri Sep 06, 2019 6:37 am
Just make a few variations of the source object with a different color.
Asus z9ped8ws/2x Intel Xeon E5-2692 v2/64gb ram/GTX1080+GTX 1070+GTX 980Ti/Samsung SSD 850 EVO 250 gb/
Octaneplugin+Lightwave 3d)
promity
Postby Sinelab01 » Sat Sep 07, 2019 10:00 am
Sinelab01 Sat Sep 07, 2019 10:00 am
Thanks for looking into it for me and explaining the issue I just added separate models in the instancer in the end. Thanks
Sinelab01
Return to Lightwave 3D
Users browsing this forum: No registered users and 5 guests
Sun Aug 09, 2020 2:34 pm [ UTC ]
