Sharpness !
Forums: Sharpness !
Sharpness !
Postby BorderLine » Wed Aug 21, 2019 12:50 pm
BorderLine Wed Aug 21, 2019 12:50 pm
Hello,
I need to have the best setting possible for maximum sharpness.
Someone can help me ?
I've 6 Titan X, no problem with render time !
BorderLine
Re: Sharpness !
Postby KVNOODLES » Wed Aug 21, 2019 4:37 pm
KVNOODLES Wed Aug 21, 2019 4:37 pm
You can play with the Filter Size option in the kernel options.
By default the value is set to 1.25, but you can reduce it to 1...
Values under 1 may cause crisp glitches.
Be carreful to the Hot Pixels Visibility is set to 100% or 1.0, values under 1.0 can be use to remove some isolated grain in your image, but you'll loose the sharpness, same thing if you use the denoiser in the Imager Camera...
KVNOODLES
Re: Sharpness !
Postby BorderLine » Wed Aug 21, 2019 4:50 pm
BorderLine Wed Aug 21, 2019 4:50 pm
Interesting ! Thanks !
BorderLine
Return to Lightwave 3D
Who is online
Users browsing this forum: No registered users and 5 guests
Sun Aug 09, 2020 3:05 pm [ UTC ]
