Render Tag
Posted: Wed Jul 24, 2019 7:24 pm
by wireframex
Could you tell me if it possible to tag the renders with the date, time rendering, size ... ?
Phil
Re: Render Tag
Posted: Thu Jul 25, 2019 7:36 am
by juanjgon
In the render target root node options panel you have an option "Overlay Statistics" that you can use add some information to the rendered images (in the image viewer or if saved using the LightWave native saving function for the beauty pass). Not sure if this is what you are looking for ...
Re: Render Tag
Posted: Thu Jul 25, 2019 5:39 pm
by wireframex
Thanks a lot
It was exactly what I need
Re: Render Tag
Posted: Wed Aug 07, 2019 10:55 pm
by Lewis
Juan, is there a chance to make that option to be Render Pass ?
To be part of a render pass node just like separate pass so we can have it for our final renders (since LW Octane F9 render time isn't visible on LW native image viewer anyway). That way we could have it on multiEXR as a separate layer and know exact render-times but without sacrificing final render image size (no need to crop out that bottom part for statistics).
Re: Render Tag
Posted: Fri Aug 16, 2019 10:02 am
by juanjgon
The problem is that from the plugin side we can't overlay information into the Octane native passes system. The plugin only can overlay information over the image exported by LightWave.
Re: Render Tag
Posted: Fri Aug 16, 2019 8:13 pm
by Lewis
juanjgon wrote:The problem is that from the plugin side we can't overlay information into the Octane native passes system. The plugin only can overlay information over the image exported by LightWave.
Thank can you please ask OTOY to change/iplement that
I really hate that i don't know rendertime on each of my F10 renders and i don't want to overlay it on my final renders since then it's "burned in" to the render.
