vdb sdf polygon smoothing
Forums: vdb sdf polygon smoothing
Postby mstewart152 » Mon Jun 24, 2019 7:01 pm
mstewart152 Mon Jun 24, 2019 7:01 pm
is there a way to smooth across normals? using imported vdb file.
mstewart152
Re: vdb sdf polygon smoothing
Postby haze » Mon Jun 24, 2019 7:29 pm
haze Mon Jun 24, 2019 7:29 pm
It's not really a good solution but you could tweak your ray epsilon.
haze
Postby mstewart152 » Wed Jun 26, 2019 3:37 pm
mstewart152 Wed Jun 26, 2019 3:37 pm
ray epsilon is not gona work . Am I missing something? the smooth option in the material seems to have no affect.
mstewart152
Postby juanjgon » Wed Jun 26, 2019 5:02 pm
juanjgon Wed Jun 26, 2019 5:02 pm
Can you please share the scene to take a look at it here?
juanjgon
Postby mstewart152 » Wed Jun 26, 2019 7:50 pm
mstewart152 Wed Jun 26, 2019 7:50 pm
thanks, but no real reason to now, this method doesnt look like its going to work. Im trying to get a realflow simulation of a creek into a pretty heavy scene..... Octane can load vdb's, but if i go that route, the vdb file size for the detail to be retained in the creek is insane. using a mesh sequence would produce the best results, but that would add days of render time for Full scene reloads in Octane. Any Ideas on how to approach this?
mstewart152
Postby mstewart152 » Wed Jun 26, 2019 10:49 pm
mstewart152 Wed Jun 26, 2019 10:49 pm
Ok so I might end up using this this method after all. Tweaked some settings for the vdb and got the file sizes down. Main thing is the smoothing in octane not working. It’s not a vdb file in lightwave, it’s being imported directly into octane,. Is this suppose to support smoothing?
mstewart152
Postby juanjgon » Thu Jun 27, 2019 7:29 am
juanjgon Thu Jun 27, 2019 7:29 am
The smoothing could work, but the problem can be that each big not smoothed polygon is made with a bunch of smaller coplanar polygons, so in this case the full smoothing is not possible because it only happens in the border of the big polygons. Perhaps Octane has this limitation while rendering VDBs ... It is hard to say without taking a look at the object.
juanjgon
Postby mstewart152 » Thu Jun 27, 2019 3:05 pm
mstewart152 Thu Jun 27, 2019 3:05 pm
here is 1 vdb frame to test with. :)
rendr_vdb_test_0211.zip
(5.05 MiB) Downloaded 26 times
mstewart152
Return to Lightwave 3D
Sun May 31, 2020 2:46 pm [ UTC ]
