Delay and problem with IPR
Forums: Delay and problem with IPR
Postby spigolo » Sat Jun 08, 2019 5:51 pm
spigolo Sat Jun 08, 2019 5:51 pm
Hello
i m working with Lw 2019.03 and lates Octane 4.04 plugin but Im having stange issues with the IPR which I didn't noticed somedays ago.
I have ot say that yesterday I have reinstalled windows 10 and updated lightwave and the Octane plugin, (previously everything was fine)
The problem I have is that when I open the IPR it stays often on hold for some seconds without any notice about loadinggeometry etc etc.
Then after a while it shows just the environment (no objects loaded).
If then I press reload everything works..
The scene Im working is full of instances and lot of geometry but In the past I have made scenes heavier than this without any issue like this, maybe it took a bit for Ipr to load everything but at the end it was showing everything..
now I have to do this in 2 step.first load nothing than reload...
What could be the cause?
Kind regards
3dsign studio
Advanced visual communication
http://www.3dsign.it
spigolo
Re: Delay and problem with IPR
Postby juanjgon » Sun Jun 09, 2019 9:54 am
juanjgon Sun Jun 09, 2019 9:54 am
Sorry, I'm not sure what could be the problem. I can understand that the scene extraction could be huge if the scene is complex with a lot of instances, especially if the motion blur is enabled, but in the end, the IPR rendering should be fine. Could you send me a scene with this problem to try to reproduce this problem here?
juanjgon
Postby spigolo » Sun Jun 09, 2019 4:46 pm
spigolo Sun Jun 09, 2019 4:46 pm
Ok I will if you send me again your email.
I also have a new issue that I have never seen before...
Its an old scene that worked fine before installing 4.04 (before it was 4) and a fresh install of windows 10...
3dsign studio
spigolo
Postby spigolo » Sun Jun 09, 2019 5:03 pm
spigolo Sun Jun 09, 2019 5:03 pm
Ok enabling out of core fixed this latest issue...
3dsign studio
spigolo
Postby juanjgon » Tue Jun 11, 2019 5:55 pm
juanjgon Tue Jun 11, 2019 5:55 pm
I've been trying to reproduce your first problem here, but without luck so far. Here the IPR always load and render the scene without problems. I wonder if the problem could be related to the drivers, but it is hard to say. Here I'm working with the .419 drivers without problems.
juanjgon
Postby spigolo » Fri Jun 14, 2019 3:55 pm
spigolo Fri Jun 14, 2019 3:55 pm
Thanks Juanjo I will check the drivers.
Kind regards
3dsign studio
spigolo
Return to Lightwave 3D
Users browsing this forum: Google [Bot] and 1 guest
Thu May 28, 2020 8:13 am [ UTC ]
