Texture inversion when using Sun Control - bug?
Forums: Texture inversion when using Sun Control - bug?
Postby panphoto » Fri Apr 05, 2019 4:32 pm
panphoto Fri Apr 05, 2019 4:32 pm
I'm getting a texture inversion simply by switching Long-Lat-Date to Direction. The 2 attached pics have no other adjustments. Any ideas please?
David
panphoto
Re: Texture inversion when using Sun Control - bug?
Postby juanjgon » Fri Apr 05, 2019 5:27 pm
juanjgon Fri Apr 05, 2019 5:27 pm
You are not inverting the texture, you are changing the lighting sun direction, something that affects the material bump, normal or displacement map lighting. If you add an object to see the direction of the shadows, you could check it yourself.
juanjgon
Postby panphoto » Fri Apr 05, 2019 8:29 pm
panphoto Fri Apr 05, 2019 8:29 pm
Hi Juanjgo,
Thanks for your reply. I fully understand what you say about sun direction. Having restarted my machine the problem has gone away! But as can be seen from the original 2 pictures there is a difference - one shows dark crests, the other shows dark crevices. Reloading the IPR didn't help, but as I say, restarting has fixed it. Could this be a cache issue, - cleared after restarting? Do please scrutinize the pictures again, I think you will see what I mean.
David
panphoto
Return to Lightwave 3D
Users browsing this forum: No registered users and 5 guests
Tue Jan 28, 2020 1:31 am [ UTC ]
