This material crashes LW 2019 everytime
Posted:
Sun Mar 31, 2019 5:39 pm
by joseburgos
I exported this material out of Daz Octane like I have done many times before. I add it through LiveDB Material but IPR does not show the material. So I click on Reload in IPR and then LW crashes. I also tested it with Octane 4 desktop and the material works there.
Oh and this material I upload I created by re-saving the material through Octane desktop as I wanted to see if it would fix the crash but it did not.
Re: This material crashes LW 2019 everytime
Posted:
Mon Apr 01, 2019 9:10 pm
by juanjgon
What plugin version are you using? I'm testing your material here with the latest build and it seems to work fine. If you get a crash with it, I'm going to need an example scene to try to reproduce the problem here.
Posted:
Fri Apr 05, 2019 12:18 am
by joseburgos
So yes if I add this texture to a simple cube, it does work so it is not the material.
How can I send you the scene file with objects because it is something I purchased and do not want to post to the public forum
Posted:
Fri Apr 05, 2019 1:17 am
by joseburgos
So it looks like when I updated to latest plugin version, I did not check Enable out of core textures. I enabled it and all is fine as of right now
