OctaneRender™ 2018.1 for LightWave™ beta build 2018.1.0.4
Forums: OctaneRender™ 2018.1 for LightWave™ beta build 2018.1.0.4
Postby juanjgon » Fri Feb 15, 2019 11:52 pm
juanjgon Fri Feb 15, 2019 11:52 pm
This is a new beta release of the OctaneRender™ 2018.1 for LightWave™ plugin version 2018.1.0.4, available for LightWave 11.6, 2015.3, 2018.0 and 2019.0 Windows x64 and OSX. This build has been compiled using the Octane 2018.1 RC4 core.
As with all experimental releases, please do not use this for production purposes. 2018.1 RC4 will expire in 60 days
New features
To learn more about the new features and improvements of OctaneRender 2018.1, please check out the 2018.1 release post, but this a quick list of the main new features that have been added:
  • NV Link support on RTX 2080 and RTX 2080 Ti
  • Cryptomatte. Currently, in the LightWave plugin, the Instance ID is used also as Object ID due to its internal scene graph architecture.
  • Vertex Attributes in the mesh objects. New options in the Octane object properties custom object plugin to configure the attributes to be extracted.
  • New "Color Vertex Attribute" and "Float Vertex Attribute" nodes to retrieve the vertex attributes in the shaders.
  • Deep render passes.
  • Way less Volume Render Noise. New option in the kernels to disable this feature if the matching of the Octane v4 volumes is needed.
  • Direct Levelset surface rendering. New option in the Octane volumetrics custom object plugin to configure the OpenVDB rendering to work with SDFs and assign their Octane material nodes.
  • Scatter depth limiting (i.e. fast fog rendering)
  • Overall 5% faster than V4 stable (about 315 OB vs 298 OB in our tests)
  • Vectron (Vector Primitive)
Release 2018.1.0.4 regular license
https://render.otoy.com/customerdownloa ... _Win64.zip
https://render.otoy.com/customerdownloa ... ve_OSX.zip
Release 2018.1.0.4 subscription license
https://render.otoy.com/customerdownloa ... n64_vr.zip
https://render.otoy.com/customerdownloa ... OSX_vr.zip
Standalone 2018.1 RC4 version for the network rendering nodes
https://render.otoy.com/customerdownloa ... C4_win.exe
https://render.otoy.com/customerdownloa ... _macos.dmg
Release Notes:
RELEASE 2018.1.0.4
* PLUGIN FEATURES AND BUGS FIXED:
- New "Shutter alignment" option in the render target root node motion blur options panel.
- Proper default file types in the lut and osl nodes file dialog windows.
- New volumetrics phase node that can be used to animate this parameter in the volume and scattering medium nodes.
* OCTANE FEATURES AND BUGS FIXED:
- Fixed crash when trying to save cryptomatte object layer passes.
- Fixed emission with mix material.
- Fixed incorrect render when the same VDB is loaded as SDF and as fog volume.
- Fixed subdivision with vertex attributes (fixes several ABC loading issues).
- Fixed LiveDB downloads sometimes failing and OctaneLive getting disconnected.
- Fixed incorrectly exported 16 bit and 32 bit HDR images
- Fixed network rendering with deep images.
- Fixed some incorrect behaviour in the universal material when using IOR=1 / transmission=1 and caustic blur.
- Fixed tonemap failure if over-under stereo is being used on small resolutions and with the eyes swapped.
- Fixed render failure when rendering a vectron node with an OSL texture input.
- Fixed render failure when trying to use vertex attributes with displacement. This is not yet supported, but planned.
- Fixed using greyscale images as opacity maps.
- Fixed normals for spheres with motion blur.
Happy rendering,
Your OTOY Team
Computer Graphics Software Developer
Octane plugin development and support: LightWave and Houdini
juanjgon
Re: OctaneRender™ 2018.1 for LightWave™ beta build 2018.1.0.4
Postby adhesivex » Sat Feb 16, 2019 12:12 am
adhesivex Sat Feb 16, 2019 12:12 am
Thank you Juanjgon! Just simply awesome.
adhesivex
Postby SpawnSP » Sun Feb 17, 2019 3:56 pm
SpawnSP Sun Feb 17, 2019 3:56 pm
juanjgon wrote:- New "Shutter alignment" option in the render target root node motion blur options panel.
Many thanks for this, juanjgon. Is there any chance to see this feature also on the Octane 4 plugin? That's the version I'm using (my fault for not specifying it)
Thanks again!
SpawnSP
Postby LightwaveGuru » Mon Feb 18, 2019 10:12 am
LightwaveGuru Mon Feb 18, 2019 10:12 am
hurra! LAVA TIME! :)
snip lwguru
LightwaveGuru
Postby juanjgon » Mon Feb 18, 2019 12:48 pm
juanjgon Mon Feb 18, 2019 12:48 pm
Thanks again!
Yes, I'll include this feature in the next 4.02 plugin build. I'll let you know when I have this ready to send you a custom build before the release if you need it.
juanjgon
Postby SpawnSP » Mon Feb 18, 2019 3:59 pm
SpawnSP Mon Feb 18, 2019 3:59 pm
juanjgon wrote:Yes, I'll include this feature in the next 4.02 plugin build. I'll let you know when I have this ready to send you a custom build before the release if you need it.
There's no hurry, don't worry. I can work with the current version and go for the final render when the new version is out.
Thanks!
SpawnSP
Postby Mastoy » Tue Feb 19, 2019 8:02 am
Mastoy Tue Feb 19, 2019 8:02 am
The standalone for network rendering doesn't seem to install the render deamon, can someone confirm ?
Mastoy
Postby BorisGoreta » Tue Feb 19, 2019 8:49 pm
BorisGoreta Tue Feb 19, 2019 8:49 pm
I really need volume rendering improvements in 2018 but I still haven't updated because I don't know how much licenses I need to buy to run 1 master and 2 render nodes.
BorisGoreta
Postby BorisGoreta » Tue Feb 19, 2019 9:26 pm
BorisGoreta Tue Feb 19, 2019 9:26 pm
Yes, there is no octane_slave.exe installed !
BorisGoreta
Postby Mastoy » Tue Feb 19, 2019 9:33 pm
Mastoy Tue Feb 19, 2019 9:33 pm
BorisGoreta wrote:Yes, there is no octane_slave.exe installed !
I just saw that here : viewtopic.php?f=33&t=70675
Please be aware that Studio builds of 2018.1 now support only 1 GPU, and no network rendering
WTF ???
Mastoy
Next
Return to Lightwave 3D
Who is online
Users browsing this forum: No registered users and 2 guests
Wed Jul 08, 2020 2:25 pm [ UTC ]
cron
