I have to animate the phase in the volume medium but no env. button is there...
Which Lightwave nodal tool/fonction can I plug into the phase entry ? I've tried several nodal items but it doesn't connect at all...
Any idea ?
Thanks.
juanjgon wrote:Hmm, there is a problem with this input. The phase input type is indeed designed to link an Octane phase node, but this node has never been exposed in the LightWave plugin because it is embedded inside the medium nodes, so it is not needed at all.
To animate the phase I need to add the "E" button to this parameter. I'll add it for the next build, but if you need it before this next release, please send me a pm with the LightWave and Octane versions that you are using and I'll try to send you a custom build with this feature as soon as possible.
Users browsing this forum: No registered users and 14 guests
