RAM usage very high
Forums: RAM usage very high
Re: RAM usage very high
Postby LichtUndSchatten » Fri Oct 26, 2018 12:00 pm
LichtUndSchatten Fri Oct 26, 2018 12:00 pm
Juanjo. Is it possible to integrate into Octane Plugin the Limited Region Feature "Border Off" function.
This would be the solution to divide up my big resolution in smaller areas which could deal the denoise function. At the moment with "Border off" modus
Octane ignores it and always create the whole resolution output.
Greetings
LichtUndSchatten
Postby juanjgon » Sat Oct 27, 2018 7:45 am
juanjgon Sat Oct 27, 2018 7:45 am
Nope, sorry, this is not possible in Octane. At the end, the render region is always working over the full image frame buffer.
The solution can be to use multiple cameras (or animate the camera) to render the different zones of the full image. I had seen a post about how to set up a camera like that. I'm going to try to find it.
juanjgon
Postby 3dworks » Sun Oct 28, 2018 10:29 am
3dworks Sun Oct 28, 2018 10:29 am
juanjgon wrote:Nope, sorry, this is not possible in Octane. At the end, the render region is always working over the full image frame buffer.
maybe it was at this thread here https://forums.newtek.com/showthread.php?140158-Free-Script-Split-Frame&p=1367824&viewfull=1#post1367824
note there's a V1.1 in the last part of the thread.
hopefully still working with LW2018. tested as working with older LW and octane.
3dworks
Postby 3dworks » Sun Oct 28, 2018 10:47 am
3dworks Sun Oct 28, 2018 10:47 am
hopefully stimm working with LW2018. tested as working with older LW and octane.
I'm getting an lscript error here on LW2018 and on macOS. anyone with a better solution? for using such a script with octane it would need to save out separate scenes with cameras set in a way that it would work without limited region. the reason is that octane cannot render 'cropped' regions in LW without needing the whole frame loaded - as junanjo explained before. i guess this is only possible with shift cameras, but tell me if i'm wrong.
3dworks
Postby promity » Sun Oct 28, 2018 3:05 pm
promity Sun Oct 28, 2018 3:05 pm
btw - new plugin for lw - Frame Split
https://forums.newtek.com/showthread.ph ... plit-Frame
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
Postby LichtUndSchatten » Mon Oct 29, 2018 11:06 am
LichtUndSchatten Mon Oct 29, 2018 11:06 am
All the plugins i´ve seen "only" dividing up the whole frame into different limited region segments.
But because of the limitation that "The render region is always working over the full image frame buffer."
an denoiser is not supported for resolution higher than about 4 k this is not a useful solution.
So we need a solution which takes lens shift x + y into account and creates new individual cameras with the
possibility of some overlap.
juanjgon. Is it possible taht yould give us the exact pixel limitation for using denoiser?
LichtUndSchatten
Previous
Return to Lightwave 3D
Who is online
Users browsing this forum: No registered users and 12 guests
Fri Apr 19, 2024 12:57 am [ UTC ]
cron
