How to use Local Livedb ?
Forums: How to use Local Livedb ?
Postby wireframex » Thu Apr 26, 2018 8:30 pm
wireframex Thu Apr 26, 2018 8:30 pm
I'm sure there is something about it but I didn't found how to use Local LiveDB.
Phil
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 531.41 - Octane Plugin Build 2021.1.7.0
Licensed: Softimage 2012 SP1 / Lightwave 2020.2.3 / modo 16.2
wireframex
Re: How to use Local Livedb ?
Postby juanjgon » Thu Apr 26, 2018 11:35 pm
juanjgon Thu Apr 26, 2018 11:35 pm
The localDB works like the liveDB feature, but you need to set the folder that will be used to store the materials in the plugin options panel, Options tab (the first parameter).
juanjgon
Postby wireframex » Fri Apr 27, 2018 8:28 pm
wireframex Fri Apr 27, 2018 8:28 pm
Hello Juan,
I have done it but I can't see the material in the window maybe I forgot something ...
Phil
Main Computer:
wireframex
Postby juanjgon » Sun Apr 29, 2018 7:01 pm
juanjgon Sun Apr 29, 2018 7:01 pm
Hmm, but this seems a copy of the LiveDB data inside your LocalDB folder. If you are trying to download LiveDB materials you should get them from the LiveDB tab. What is the origin of all these folders in your LocalDB directory?
juanjgon
Postby wireframex » Sun Apr 29, 2018 9:19 pm
wireframex Sun Apr 29, 2018 9:19 pm
Hi Juan
I downloaded it from Otoy web but it seems it works only with modo. I believe these livedb in local will work with Lightwave too.
I prefer to use these materials in local.
Phil
Main Computer:
wireframex
Postby juanjgon » Mon Apr 30, 2018 9:21 pm
juanjgon Mon Apr 30, 2018 9:21 pm
Sorry, I think that these materials are already converted to the Modo format, so they are not going to work with LightWave. You need to use the online LiveDB database.
juanjgon
Return to Lightwave 3D
Users browsing this forum: No registered users and 7 guests
Tue Apr 23, 2024 12:56 pm [ UTC ]
