OSL Shader like VRoom - Check it out
Forums: OSL Shader like VRoom - Check it out
Re: OSL Shader like VRoom - Check it out
Postby baltort » Thu Apr 26, 2018 7:59 pm
baltort Thu Apr 26, 2018 7:59 pm
pxlntwrk wrote:Great ! Thank you very much ! ;)
Moreover in cinema 4d, there is an input slot for the template!
The C4D solution is very elegant, but I can't see a way to carry it over to LW. As far as I can see, there's no way to pass a texture filename as a string into a LW node. You can pass a texture as colour information, but this relies on the UV coordinates of the sample point and delivers a single pixel sample of info rather than the whole texture. The box room idea needs multiple samples for the walls, mid-ground, and curtain layer to make a single output sample.
I shall investigate further to see if it's workable!
J.
baltort
Postby juanjgon » Thu Apr 26, 2018 11:37 pm
juanjgon Thu Apr 26, 2018 11:37 pm
Thanks! Really cool. Yes, in LW we have the limitation related to the fact that there is not a "string" type node. Let me think about it. I suppose that I could add a custom node type to support this kind of parameters.
juanjgon
Postby KVNOODLES » Sat Apr 28, 2018 2:42 pm
KVNOODLES Sat Apr 28, 2018 2:42 pm
It could be so great !
KVNOODLES
Postby 3dworks » Sat Aug 25, 2018 9:04 am
3dworks Sat Aug 25, 2018 9:04 am
juanjgon wrote:Thanks! Really cool. Yes, in LW we have the limitation related to the fact that there is not a "string" type node. Let me think about it. I suppose that I could add a custom node type to support this kind of parameters.
is this still on the agenda? would be great! :-)
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
3dworks
Postby nico_cad » Wed Nov 21, 2018 2:54 pm
nico_cad Wed Nov 21, 2018 2:54 pm
hi guys, we have need your help.
in lw native can use a random image on objetc and obtain this render.
if want similar effect in octane what's the procedure?
I do not understand how to use osl.
thanks for help :D
lw native
nico_cad
Postby nico_cad » Wed Nov 21, 2018 5:45 pm
nico_cad Wed Nov 21, 2018 5:45 pm
baltort wrote:Hi all,
I've had a bit of a hack at the code and got it working at my end. I'm hardcoding the texture into the OSL file, so you'll need to correct for your own file location. If you're on windows then make sure you use forward slashes in the path as shown. I've also had to tweak the co-ordinate system and modify the boolean pins to integers. All credit to Julius Ihle for making it in the first place!
Cheers,
James
james!!!! how can use it? i see only my cube?!?!?!?!?
can share the scene?
:o :o
nico_cad
Postby nico_cad » Thu Nov 22, 2018 9:15 am
nico_cad Thu Nov 22, 2018 9:15 am
ok works fine!!! now is necessary randomize the image!! :P
nico_cad
Previous
Return to Lightwave 3D
Users browsing this forum: No registered users and 16 guests
Thu Apr 25, 2024 4:20 pm [ UTC ]
