Cuda 700 errors?
Forums: Cuda 700 errors?
Cuda 700 errors?
Postby johnkarner » Wed Dec 20, 2017 2:55 am
johnkarner Wed Dec 20, 2017 2:55 am
Running 3.05.3 on a titan X pascal
Rendering 22+ scenes all using the same objects
but on ONE scene, after frame 8, it crashes consistently
00:01:26 (0086.01) | <> Mem Used/Free/Total: 899 / 9075 / 12288
00:01:26 (0086.01) | <> Triangles/DisplaceTris/Hairs/Objects/Voxels rendered: 958266 / 0 / 0 / 1058 / 0
00:01:26 (0086.01) | <> Textures RGB32/RGB64/GREY8/GREY16 used: 15 / 3 / 0 / 0
00:01:26 (0086.01) | ... Init rendering ...
00:01:26 (0086.55) | >>> processing image callback
00:01:26 (0086.55) | Reading preview image
00:01:26 (0086.55) | ... Get sampling information
00:01:26 (0086.55) | ... Statistics: 1 of 300 samples, 0 sec, 5.51 Ms/sec
00:01:26 (0086.55) | ... Get buffers resolution
00:01:26 (0086.55) | ... Resolution: 1920 1080
00:01:26 (0086.55) | ... Check compositing
00:01:26 (0086.55) | ... Compositing 0
00:01:26 (0086.55) | ... Reading frame buffer
00:01:26 (0086.57) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:01:26 (0086.57) * OCTANE API MSG: -> kernel execution failed(report)
00:01:26 (0086.57) * OCTANE API MSG: -> failed to launch kernel(ptBrdf2)
00:01:26 (0086.57) * OCTANE API MSG: device 0: direct light kernel failed
00:01:26 (0086.57) * OCTANE API MSG: device 0: detected an error on render device! trying to recover...
00:01:26 (0086.57) * OCTANE API MSG: -> failed to deallocate device memory
00:01:26 (0086.57) * OCTANE API MSG: -> could not get memory info
00:01:26 (0086.58) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:01:26 (0086.58) * OCTANE API MSG: -> could not get memory info
00:01:26 (0086.58) * OCTANE API MSG: -> failed to deallocate device memory
00:01:26 (0086.58) * OCTANE API MSG: -> failed to deallocate device array
00:01:26 (0086.59) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:01:26 (0086.59) * OCTANE API MSG: -> failed to deallocate device memory
00:01:26 (0086.59) * OCTANE API MSG: -> could not get memory info
00:01:26 (0086.59) * OCTANE API MSG: -> failed to deallocate pinned memory
00:01:26 (0086.59) * OCTANE API MSG: -> failed to unregister pinned memory
00:01:26 (0086.59) * OCTANE API MSG: -> failed to unload module
00:01:26 (0086.84) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:01:26 (0086.84) * OCTANE API MSG: -> failed to bind device to current thread
00:01:26 (0086.84) * OCTANE API MSG: device 0: failed to initialize resources
00:01:26 (0086.84) * OCTANE API MSG: device 0: failed to recover - giving up and switching device to failed
00:01:27 (0087.75) | Reading preview image successfully
00:01:27 (0087.75) | >>> Refresh preview window
00:01:27 (0087.75) | >>> Refresh preview window done
00:01:27 (0087.75) | ++++++++++++++++++++++
00:01:27 (0087.75) | +++ RENDER FAILURE +++ processing the failure callback
johnkarner
Re: Cuda 700 errors?
Postby juanjgon » Wed Dec 20, 2017 9:46 am
juanjgon Wed Dec 20, 2017 9:46 am
Have you tried to render your scene using one of the latest plugin builds (3.07.0.1 or 3.08.0.0)? If it is a bug in the Octane core perhaps it is fixed now. If not, we are going to need the scene to try to reproduce the problem here.
juanjgon
Postby mikefrisk » Wed Dec 20, 2017 7:27 pm
mikefrisk Wed Dec 20, 2017 7:27 pm
You could try setting your TdrDelay longer. I don't necessarily think that is your issue but it's worth a shot.
Open regedit. Go to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers" and create a key of type "DWORD (32-bit)" and name "TdrDelay" with a decimal value of like 100.
I was getting several cuda 700 and 702 errors and increasing this timeout completely fixed my issue.
mikefrisk
Return to Lightwave 3D
Who is online
Users browsing this forum: No registered users and 4 guests
Tue Apr 16, 2024 9:27 am [ UTC ]
