Displacement smooth
Forums: Displacement smooth
Displacement smooth
Postby scratch33 » Thu Nov 09, 2017 11:27 pm
scratch33 Thu Nov 09, 2017 11:27 pm
I have some problems with displacement.
Why do I have this "pixelisation effect"???
I use a 16 bit png then tiff 4096x4096 image to displace a plane. I have tryed to add more geometry, augmented subpatch, smooth on, But nothing, result is always like this.
Any suggestion? thanks
scratch33
Re: Displacement smooth
Postby mikefrisk » Fri Nov 10, 2017 12:08 am
mikefrisk Fri Nov 10, 2017 12:08 am
This is unfortunately damn near unavoidable, your only option is to increase the "level of detail" in the displacement node.
Edit: Also, the poly count of your geometry does not matter, which is what makes octane displacement wonderfully powerful, keep your ground plane a single polygon. If your geometry curves, however, you will have seams at polygon edges.
mikefrisk
Postby Builtdown » Fri Nov 10, 2017 7:20 am
Builtdown Fri Nov 10, 2017 7:20 am
Is the displacement image covering a very large area like 200m x 200m?
You might need to cut the area in smaller areas.
Builtdown
Postby scratch33 » Fri Nov 10, 2017 8:11 am
scratch33 Fri Nov 10, 2017 8:11 am
Thanks for reply.
My map is 4096x4096 and I use 4096x4096 level of detail.
Level detail is drived by the resolution. but what I don't understand is why we can't smooth the polygon without adding any detail.
Builtdown, my object is 16mx16m.
Is there any tips on what format, what resolution, or other advice to have a better result in displacement?
I have tried to import megascan maps and I can't do any close up view without having but results.
I don't understand Where I'm wrong.
Francesco
scratch33
Postby juanjgon » Fri Nov 10, 2017 10:43 am
juanjgon Fri Nov 10, 2017 10:43 am
To have a better resolution you can use up to 8k texture maps (Level of detail 8192) and enable the Box or Gaussian Filtering, but well, if you take a really close up view, finally you are going to see this pixelation effect because this is how Octane works.
juanjgon
Postby BorisGoreta » Fri Nov 10, 2017 5:15 pm
BorisGoreta Fri Nov 10, 2017 5:15 pm
If the mesh is curved turn on smoothing to avoid the seems.
BorisGoreta
Return to Lightwave 3D
Users browsing this forum: Bing [Bot] and 28 guests
Thu Apr 25, 2024 1:18 pm [ UTC ]
